Page 1 of 3 1 2 3
Copper in oil filter #2963033
09/11/21 05:18 PM
09/11/21 05:18 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hi folks
Opened the oil filter the day before the race tomorrow as it has been awhile. I used to do it after every day of racing last season when the motor was fresh . Never anything much. Talking 3-5 passes.
This season I got lazy . Changed the oil as normal often but not the filter. There are about 40 passes on this filter. Motor has maybe 60 .
This looks scary to me . Thoughts from experience?
There is one other spot with a heavy deposit , but having a hard time loading pics from the track
Re: Copper in oil filter [Re: Wirenut] #2963038
09/11/21 05:27 PM
09/11/21 05:27 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
looks like brass gear to me...
Re: Copper in oil filter [Re: ek3] #2963062
09/11/21 06:42 PM
09/11/21 06:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Good call........ and easy to check.
Re: Copper in oil filter [Re: fast68plymouth] #2963065
09/11/21 06:52 PM
09/11/21 06:52 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks guys.
Tomorrow I will be a spectator. I’ll drag it home after the race and get the gear out and let you know what I find .
Thanks for the opinion and giving me hope .
Gary
Re: Copper in oil filter [Re: Wirenut] #2963173
09/12/21 09:04 AM
09/12/21 09:04 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think bronze gear going away.
Re: Copper in oil filter [Re: lewtot184] #2963179
09/12/21 09:52 AM
09/12/21 09:52 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Pulled it out
Gear teeth look good . Bottom side of gear seams to have recess with a sharp edge worn in it
Re: Copper in oil filter [Re: Wirenut] #2963186
09/12/21 10:10 AM
09/12/21 10:10 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good of you to cut the filter open!
Re: Copper in oil filter [Re: HardcoreB] #2963195
09/12/21 10:43 AM
09/12/21 10:43 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
What does the bushing look like in the block?
Re: Copper in oil filter [Re: actionange] #2963226
09/12/21 12:52 PM
09/12/21 12:52 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
do you have a collar on the distributor shaft trying to control end play?
Re: Copper in oil filter [Re: lewtot184] #2963261
09/12/21 02:43 PM
09/12/21 02:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
End play is not the culprit ... you have "similar" metals in friction contact with each other. If you'd had a thin steel torrington washer between the gear and the bushing you wouldn't have had this problem.
Re: Copper in oil filter [Re: Stanton] #2963262
09/12/21 02:45 PM
09/12/21 02:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And FWIW, that gear is still usable - just machine off the ridge and put a torrington washer between the two. The fact the teeth aren't worn means its getting along just fine with your cam.
Re: Copper in oil filter [Re: actionange] #2963271
09/12/21 03:39 PM
09/12/21 03:39 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Ok I think
I’m home now and can get a pick of it. One thing that did strike me was it appears to be flush and maybe even slightly recessed into the block . Not sure if I have any picks from the build that would show it
Thanks for all the thoughts
Re: Copper in oil filter [Re: lewtot184] #2963272
09/12/21 03:41 PM
09/12/21 03:41 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
No
Re: Copper in oil filter [Re: Wirenut] #2963274
09/12/21 03:44 PM
09/12/21 03:44 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
So when I had the gear out today I put some ot the debris chips next to it and they don’t look to be the same color . The debris looks copper to me
Re: Copper in oil filter [Re: Stanton] #2963276
09/12/21 03:51 PM
09/12/21 03:51 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Is there or should there normally be a steel washer under the gear? Could I have missed it in the rebuild? And if I did would it take this long to show itself?
Re: Copper in oil filter [Re: Wirenut] #2963284
09/12/21 04:33 PM
09/12/21 04:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
factory never used any shim between the gear and bushing. they had dissimilar metals. they only other place to get copper shavings i can think of is the crank thrust bearing. the thrust on the cam and intermediate shaft gears is down, but a worn bushing will allow for some thrust towards the rear of the engine in combination with the downward pressure.
Re: Copper in oil filter [Re: Wirenut] #2963292
09/12/21 04:41 PM
09/12/21 04:41 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Pics in the hole
Hard to see but there is a symmetrical star or radial pater in the iron around the bushing
Thanks all for looking
95BD4B55-EA31-4268-8C58-732D8D78A96B.jpeg251388AB-570F-446F-AB96-FF732514C8FB.jpeg2FC03D10-B369-4343-BB4B-672671EA3C5A.jpeg
Re: Copper in oil filter [Re: Wirenut] #2963308
09/12/21 05:28 PM
09/12/21 05:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think you know what that means.
Although, the bushing is usually more copper colored than the gear.
See if you can get a measurement of how thick the flange on the bushing is, and compare to a new one to get an idea of how much is worn off it.
Re: Copper in oil filter [Re: fast68plymouth] #2963316
09/12/21 05:45 PM
09/12/21 05:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
sometimes you have to look at how far down the shaft is pressed into the gear. it's possible for the distributor and gear to go solid if the shaft is too high in the gear and the distributor tightened down. see if you have another gear, iron or bronze, to compare against. also if that may be the case it should show up at the collar on the bottom of the distributor housing. i've had issues where i thought the shaft was pressed too deep, so it may be possible for it not to be pressed deep enough.
Re: Copper in oil filter [Re: lewtot184] #2963319
09/12/21 06:00 PM
09/12/21 06:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Factory never installed roller cams !! Solid and hydraulic cams are cast iron, gears were all steel - dissimilar metals. Steel gears against a bronze bushing - dissimilar metals. Hence no wear issues.
Page 1 of 3 1 2 3
