Copper in oil filter
#2963033
09/11/21 05:18 PM
09/11/21 05:18 PM
Posts: 630 Ct
Wirenut
Ct
Hi folks Opened the oil filter the day before the race tomorrow as it has been awhile. I used to do it after every day of racing last season when the motor was fresh . Never anything much. Talking 3-5 passes.
This season I got lazy . Changed the oil as normal often but not the filter. There are about 40 passes on this filter. Motor has maybe 60 .
This looks scary to me . Thoughts from experience?
There is one other spot with a heavy deposit , but having a hard time loading pics from the track
Re: Copper in oil filter
[Re: ek3]
#2963062
09/11/21 06:42 PM
09/11/21 06:42 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
looks like brass gear to me... Good call........ and easy to check.
[Re: fast68plymouth]
#2963065
09/11/21 06:52 PM
09/11/21 06:52 PM
Posts: 630 Ct
Wirenut
Ct
looks like brass gear to me... Good call........ and easy to check. Thanks guys. Tomorrow I will be a spectator. I’ll drag it home after the race and get the gear out and let you know what I find . Thanks for the opinion and giving me hope . Gary
[Re: actionange]
#2963271
09/12/21 03:39 PM
09/12/21 03:39 PM
Posts: 630 Ct
Wirenut
Ct
What does the bushing look like in the block? Ok I think I’m home now and can get a pick of it. One thing that did strike me was it appears to be flush and maybe even slightly recessed into the block . Not sure if I have any picks from the build that would show it Thanks for all the thoughts
[Re: lewtot184]
#2963272
09/12/21 03:41 PM
09/12/21 03:41 PM
Posts: 630 Ct
Wirenut
Ct
do you have a collar on the distributor shaft trying to control end play? No
[Re: Stanton]
#2963276
09/12/21 03:51 PM
09/12/21 03:51 PM
Posts: 630 Ct
Wirenut
Ct
End play is not the culprit ... you have "similar" metals in friction contact with each other. If you'd had a thin steel torrington washer between the gear and the bushing you wouldn't have had this problem. Is there or should there normally be a steel washer under the gear? Could I have missed it in the rebuild? And if I did would it take this long to show itself?
[Re: Wirenut]
#2963308
09/12/21 05:28 PM
09/12/21 05:28 PM
fast68plymouth
So. Burlington, Vt.
So when I had the gear out today I put some ot the debris chips next to it and they don’t look to be the same color . The debris looks copper to me I think you know what that means. Although, the bushing is usually more copper colored than the gear. See if you can get a measurement of how thick the flange on the bushing is, and compare to a new one to get an idea of how much is worn off it.
[Re: lewtot184]
#2963319
09/12/21 06:00 PM
09/12/21 06:00 PM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
factory never used any shim between the gear and bushing. Factory never installed roller cams !! Solid and hydraulic cams are cast iron, gears were all steel - dissimilar metals. Steel gears against a bronze bushing - dissimilar metals. Hence no wear issues.
