This topic is 572 B1 org Part 3 - Machine Shop ReportHere is my plan for posting progress:
572 B1 org Part 1-Buying Parts
572 B1 org Part 2-Component Observations
572 B1 org Part 3-Machine Shop Report572 B1 org Part 4-Mock-ups
572 B1 org Part 5-Build Notes
572 B1 org Part 6-Dyno Results
572 B1 org Part 7-Track Testing
Part 3-572 B1 org - Machine Shop ReportBased on Parts 1,2, and 3; along with other racer’s input; I gave the block to the machine shop for the following:
1) Bore/hone to final size for the pistons
2) Finish size the lifter bores for Comp Cams roller lifters (892-series, FWIW).
3) Check the deck for equal heights and square to the block centerline (for equal piston to deck each cylinder).
4) Install cam bearings
I also gave them the crank, rods, pistons, etc to balance the reciprocating assembly.
I dropped it all off on Monday Aug 9th.
I called 2 weeks ago, when they said it would be done; but they said another week or two.
![frown frown](/ubbthreads/images/graemlins/custom/frown.gif)
I called this morning (Sep 9th) just before lunch; and they said I can pick it up this afternoon.
![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
So, follow this post as I check out the machine work.
