Options for KD for 518 and drive by wire? #2961501
09/06/21 10:38 AM
09/06/21 10:38 AM
BDW Online content OP
BDW  Online Content OP
Current setup is 518 behind a 340, using the Bouchillion cable system and it works great.
What are people using for the throttle pressure when using the newer Gen3 electronic pedal without cables?
Re: Options for KD for 518 and drive by wire? [Re: BDW] #2962007
09/07/21 08:49 PM
09/07/21 08:49 PM
GA
roadrunninMark Offline
GA
Rod, check out this thread....it has answers for you for kickdown cable in the second post. https://board.moparts.org/ubbthread...-a-5-7-6-1-hemi-into-your-ole-mopar.html
Re: Options for KD for 518 and drive by wire? [Re: roadrunninMark] #2962323
09/08/21 08:53 PM
09/08/21 08:53 PM
Thx for the link, he does give some info, but I'm still cloudy on what exactly he did.
Unfortunately it looks like he doesn't post much, hasn't been on in 6 months.
Still looking for some details. That post was >13yrs ago, hoping someone has figured out a new hack for this.
Re: Options for KD for 518 and drive by wire? [Re: BDW] #2962397
09/09/21 07:45 AM
09/09/21 07:45 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Why not just put a manual vb in the 518? I think most guys trying to an auto with the hemi are going to the 8 spd or stay 727, which again has a manual vb
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Options for KD for 518 and drive by wire? [Re: Jerry] #2962525
09/09/21 03:40 PM
09/09/21 03:40 PM
The 727 in the car before I swapped in the 518, had a RMVB, drove that for 15yrs.
I'd like to keep the 518 shifting automatically so both my son or daughter (or anyone else) can jump in and drive the car without "special" instructions.
The whole point of the the Gen3 swap for me was to make the car more modern and trouble free so I'll drive it more.
Someone has to have crossed this bridge recently.
Re: Options for KD for 518 and drive by wire? [Re: BDW] #2962539
09/09/21 04:32 PM
09/09/21 04:32 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Is it for the e-body in your sig pic? I'm mocking up one in a 67 b-body right now. I'm going to use a Lokar kickdown cable for the 727, but installed into the original throttle cable hole, attaching it to the original pedal fulcrum bracket. The electronic pedal will push on the original bracket, which will "pull" the cable.
I just got the cable in the mail today.
Re: Options for KD for 518 and drive by wire? [Re: todd440] #2962552
09/09/21 05:59 PM
09/09/21 05:59 PM
Yes, working on a Challenger.
Was thinking along those lines, how to merge the electronic pedal with the manual cable needed.
Glad to hear your working this, would love to see what you come up with.
Thx
Re: Options for KD for 518 and drive by wire? [Re: BDW] #2962588
09/09/21 08:46 PM
09/09/21 08:46 PM
GA
GA
DIYHEMI has some good videos on youtube, here is one for your kickdown cable question.. https://www.youtube.com/watch?v=5H6Jt6G5DcA&t=474s
I believe they are using the 03-04? RAM TPS box (so you can use your old cable driven gas pedal) and hook up the kick down to that connection. I watched the video a while ago and forget all the details.
Re: Options for KD for 518 and drive by wire? [Re: BDW] #2963793
09/13/21 08:30 PM
09/13/21 08:30 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
I tried to position the pedal over top of the roller, but it was too far to the right. I had to bend the original tab that the cable ball goes in , so it would line up better with the lokar cable guide.
I may have to play with kickdown lever length to achieve the proper travel, but I think it will be close.
This was just a mock up to see how it would lay out.
Re: Options for KD for 518 and drive by wire? [Re: todd440] #2963795
09/13/21 08:32 PM
09/13/21 08:32 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Why in the hell does it take my pics and rotate them?
mad
