Page 3 of 3 1 2 3
Re: Air shocks\wide tires [Re: Sunroofcuda] #2988412
11/23/21 07:53 PM
11/23/21 07:53 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Back in 1980 a friend of mine had a 70 CUDA 440 with N50 Pro Tracts Cragers High Jackers & shock extensions, that image is forever burned in whats ever left of my mind
Re: Air shocks\wide tires [Re: exile5700] #2988621
11/24/21 12:10 PM
11/24/21 12:10 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
1982
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Air shocks\wide tires [Re: W.I.N. Racing] #2988638
11/24/21 01:06 PM
11/24/21 01:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'd try to reinforce the shock x-member where it's welded to the rear frame rails. Might not hurt to box it around the upper shock mounts either. You could use Super Stock springs to get the back up too. If it isn't enough, the air shocks can add the little bit of extra height you want. Then most of the weight would be on the springs and not so much on the shocks. twocents
Page 3 of 3 1 2 3
