Re: Engine R&R, do I need this?
[Re: Stanton]
#2959726
08/31/21 10:18 PM
08/31/21 10:18 PM
Posts: 3,138 N.W. Florida
Fat_Mike
N.W. Florida
They're handy !! For the price I'd go for it !! X2 Whether you're pulling or installing an engine transmission combination, or even just the engine (from the top), those levelers are money. I'm not saying it can't be done without one, but the job will certainly be easier.
[Re: BDW]
#2959731
08/31/21 10:27 PM
08/31/21 10:27 PM
Posts: 712 California
BigDaddy440
California
I've only used one once in countless engine pulls and installs and that was a long time ago. An issue that may come up is that sometimes you need the "hook" of the engine hoist to be near the engine to get enough height to clear the radiator support. The load lever takes up a lot of this potential lift height. So I guess it just depends on your situation.
If I need the engine to tilt a bit, I just change the lifting point on the chain or carb plate hook location.
Whatever you decide, safety first!
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2959785
09/01/21 06:06 AM
09/01/21 06:06 AM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
I had the same question, with an aluminum head big block, front and rear motor plate, giant engine setback, tall and wide fabbed aluminum valve covers, and a firewall less than 1/4" away from the back of the heads. Solution was to borrow a friends old cast iron intake,add a Summit carb pad lift plate with three hoop choices atop,tape off intake ports, use an old set or cheap set of gaskets, and temporarily bolt on to the motor. No chains or brackets to mess up valve covers or any aluminum bolt holesor surfaces. Also had no firewall/chain clearance either. Didn't want to wreck a heavily ported aluminum intake either. It worked absolutely great. It spread the load out evenly and securely on the intake manifold surface of the aluminum heads. Bill
[Re: BDW]
#2959787
09/01/21 06:32 AM
09/01/21 06:32 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Just sold mine. Never used it. Use a carb flange lifting plate
[Re: Cab_Burge]
#2960000
09/01/21 05:01 PM
09/01/21 05:01 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If I need the engine to tilt a bit, I just change the lifting point on the chain or carb plate hook location. Yup ... just drop the engine back down into place, change the hook point, try again OR just turn the crank on that gizmo !!! Actually, there are a bunch of things that will dictate whether or not you can use one of these.
[Re: 71birdJ68]
#2960103
09/01/21 08:35 PM
09/01/21 08:35 PM
Posts: 6,358 nowhere
Sniper
nowhere
Easier to drop it out the bottom Not always.
[Re: poorboy]
#2960237
09/02/21 09:01 AM
09/02/21 09:01 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
It's better to have the tool in your tool box and choose to use it or not than not have it. What guy has too many tools in his box anyways? ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: BigDaddy440]
#2960295
09/02/21 01:10 PM
09/02/21 01:10 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, that's why I don't like them.
[Re: John_Kunkel]
#2960297
09/02/21 01:20 PM
09/02/21 01:20 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Yep, that's why I don't like them. Same thing here. Good idea, but seems to get in the way in reality. In particular on a truck where the cowl hangs over the motor. Just no room.
[Re: njmopar]
#2960375
09/02/21 05:52 PM
09/02/21 05:52 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
For lifting new hemis I took a piece of angle iron, drilled a hole on each end to bolt it flat to a head via the intake bolt hole and drilled a bigger hole in the center for the tip of my cherry picker hook, very low clearance set up so I don't have to pull hoods or have the cowl in the way, done a bunch this way with no problems so far.
