Engine R&R, do I need this? #2959704
08/31/21 09:06 PM
08/31/21 09:06 PM
BDW Offline OP
BDW  Offline OP
Going to be removing my 340 and replacing with Gen3 5.7.
I have the HF 2-ton lift, do I need this leveler?
Or just a set of chain?
Re: Engine R&R, do I need this? [Re: BDW] #2959715
08/31/21 09:31 PM
08/31/21 09:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They're handy !! For the price I'd go for it !!
Re: Engine R&R, do I need this? [Re: Stanton] #2959726
08/31/21 10:18 PM
08/31/21 10:18 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
X2
Whether you're pulling or installing an engine transmission combination, or even just the engine (from the top), those levelers are money. I'm not saying it can't be done without one, but the job will certainly be easier.
Re: Engine R&R, do I need this? [Re: BDW] #2959731
08/31/21 10:27 PM
08/31/21 10:27 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I've only used one once in countless engine pulls and installs and that was a long time ago. An issue that may come up is that sometimes you need the "hook" of the engine hoist to be near the engine to get enough height to clear the radiator support. The load lever takes up a lot of this potential lift height. So I guess it just depends on your situation.
If I need the engine to tilt a bit, I just change the lifting point on the chain or carb plate hook location.
Whatever you decide, safety first!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Engine R&R, do I need this? [Re: BigDaddy440] #2959785
09/01/21 06:06 AM
09/01/21 06:06 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I had the same question, with an aluminum head big block, front and rear motor plate, giant engine setback, tall and wide fabbed aluminum valve covers, and a firewall less than 1/4" away from the back of the heads. Solution was to borrow a friends old cast iron intake,add a Summit carb pad lift plate with three hoop choices atop,tape off intake ports, use an old set or cheap set of gaskets, and temporarily bolt on to the motor. No chains or brackets to mess up valve covers or any aluminum bolt holesor surfaces. Also had no firewall/chain clearance either. Didn't want to wreck a heavily ported aluminum intake either. It worked absolutely great. It spread the load out evenly and securely on the intake manifold surface of the aluminum heads. Bill
Re: Engine R&R, do I need this? [Re: BDW] #2959787
09/01/21 06:32 AM
09/01/21 06:32 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Just sold mine. Never used it. Use a carb flange lifting plate
Re: Engine R&R, do I need this? [Re: BSB67] #2959853
09/01/21 10:57 AM
09/01/21 10:57 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Do not need.
Re: Engine R&R, do I need this? [Re: BDW] #2959914
09/01/21 01:42 PM
09/01/21 01:42 PM
It is your choice, both ways work up
Re: Engine R&R, do I need this? [Re: Cab_Burge] #2960000
09/01/21 05:01 PM
09/01/21 05:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Yup ... just drop the engine back down into place, change the hook point, try again OR just turn the crank on that gizmo !!!
Actually, there are a bunch of things that will dictate whether or not you can use one of these.
Re: Engine R&R, do I need this? [Re: Stanton] #2960036
09/01/21 05:55 PM
09/01/21 05:55 PM
BDW Offline OP
BDW  Offline OP
No carb flange on the 5.7, maybe there's a spot on the heads?
I assumed I'd bolt the chains to the intake manifold on the 340.
Wouldn't mind spending the $35 for the leveler if it will work for both engines.
Re: Engine R&R, do I need this? [Re: BDW] #2960041
09/01/21 06:06 PM
09/01/21 06:06 PM
IMGTX Offline
IMGTX  Offline
I have one and never used it. It took up too much height and didn't work for me. If I had an A-Frame hoist with more vertical space it may be fine.
On my engines I usually just hook a chain to the alternator bolt holes in the heads.
Re: Engine R&R, do I need this? [Re: BDW] #2960076
09/01/21 07:41 PM
09/01/21 07:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Easer to drop it out the bottom
Re: Engine R&R, do I need this? [Re: 71birdJ68] #2960103
09/01/21 08:35 PM
09/01/21 08:35 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Originally Posted by 71birdJ68
Easier to drop it out the bottom
Not always.
Re: Engine R&R, do I need this? [Re: Sniper] #2960107
09/01/21 08:42 PM
09/01/21 08:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Chain or carb plate here. A buddy built me one and i sol dit at a swap meet (SHHH!) whistling beer
Re: Engine R&R, do I need this? [Re: TJP] #2960128
09/01/21 09:17 PM
09/01/21 09:17 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You loose about 12" of lift height with one. If you can lift that extra foot, they are pretty nice, but very seldom could I clear the radiator support with one of those in place. Hundreds of motor swaps, that thing worked on less the 5 of them. Maybe its under a shelve someplace, but more likely, I got rid of it. Gene
Re: Engine R&R, do I need this? [Re: poorboy] #2960237
09/02/21 09:01 AM
09/02/21 09:01 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
It's better to have the tool in your tool box and choose to use it or not than not have it.
What guy has too many tools in his box anyways? boogie
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Engine R&R, do I need this? [Re: Copper Dart] #2960239
09/02/21 09:21 AM
09/02/21 09:21 AM
nowhere
nowhere
I did away with engine hoists and levelers.
Too much Rube Goldberg there.
So I built me a gantry crane. Works like a champ. I have a lifting eye I screw in place of the center head bolt.
Re: Engine R&R, do I need this? [Re: BigDaddy440] #2960295
09/02/21 01:10 PM
09/02/21 01:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, that's why I don't like them.
Re: Engine R&R, do I need this? [Re: John_Kunkel] #2960297
09/02/21 01:20 PM
09/02/21 01:20 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Same thing here. Good idea, but seems to get in the way in reality. In particular on a truck where the cowl hangs over the motor. Just no room.
Re: Engine R&R, do I need this? [Re: njmopar] #2960375
09/02/21 05:52 PM
09/02/21 05:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
For lifting new hemis I took a piece of angle iron, drilled a hole on each end to bolt it flat to a head via the intake bolt hole and drilled a bigger hole in the center for the tip of my cherry picker hook, very low clearance set up so I don't have to pull hoods or have the cowl in the way, done a bunch this way with no problems so far.
