Oil pans? #2959793
09/01/21 07:31 AM
09/01/21 07:31 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Looking at aftermarket oil pans, I see there are different pans offered for up to 2008 non VVT, thne the newer 5.7-6.4 and a separate pan for a Hellcat 6.2. What's the difference between them? I have one Steffs pan available but I believe it's for a non VVT engine. Any possibilities it would fit the Hellcat 6.2?
Plynouth VIP '67 TT IC EFI
Re: Oil pans? [Re: jyrki] #2960144
09/01/21 10:04 PM
09/01/21 10:04 PM
IL
furious70 Offline
furious70  Offline
IL
I'm not much help other than I have an 09+ pan for my eventual engine and an 05 core engine I've used for mock ups and the pan does not completely fit flush and correct, so something is different.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Oil pans? [Re: furious70] #2960597
09/03/21 11:35 AM
09/03/21 11:35 AM
Jamey Offline
Jamey  Offline
I’ve never tried but heard the bolt pattern was the same. I believe the difference is the pickup tube. That’s for everything but the 6.2, not sure about that one.
Re: Oil pans? [Re: Jamey] #2960647
09/03/21 01:27 PM
09/03/21 01:27 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
The front cover on VVT motors are bigger. I believe this is to fit the cam phase install. So no a non VVT oil pan does not fit a VVT motor.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: Oil pans? [Re: Bakaruda] #2961400
09/05/21 09:31 PM
09/05/21 09:31 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
All the aftermarket pans fit any gen 3 hemi. The pickup is different . I have used the same milodon pan on 5.7, 6.4, 6.1 enigines different pickup needed for the 6.4 and eagle 5.7.
Re: Oil pans? [Re: biff426] #2961490
09/06/21 09:29 AM
09/06/21 09:29 AM
BDW Offline
BDW  Offline
Is the Holly cast aluminum pan the best choice now?
