Re: Which Dynamat To Use?
[Re: 70sixpkrt]
#2958435
08/28/21 07:11 PM
08/28/21 07:11 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I've done with both my cars and my truck with Dynamat Extreme in bulk packs. I found it on sale on Amazon for about 1/2 off with free shipping. It is heavy. I do two layers on the wheel tubs, and one the entire floor, ceiling and doors(some strips inside and on the panel).
The key to insulating airplanes or cars is that products like dynamat are designed and are very good at reducing panel resonation, and not so much at reducing heat transfer. You actually don't even need to cover the entire surface, just use enough to stop the resonation of the panels.
For best sound deadening, heat and fume rejection, you must use a double sided foil covered insulating blanket type material on top of it. I get mine from Speedway Motors. Its very reasonably priced there.
I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fume rejection this technique provides. I learned how to do it this way reading about how they insulate small planes.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2958441
08/28/21 07:23 PM
08/28/21 07:23 PM
Posts: 6,358 nowhere
Sniper
nowhere
I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fume rejection this technique provides. I learned how to do it this way reading about how they insulate small planes. I cannot begin to imagine how much added weight that is.
[Re: jbc426]
#2958456
08/28/21 08:36 PM
08/28/21 08:36 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
I've done with both my cars and my truck with Dynamat Extreme in bulk packs. I found it on sale on Amazon for about 1/2 off with free shipping. It is heavy. I do two layers on the wheel tubs, and one the entire floor, ceiling and doors(some strips inside and on the panel). The key to insulating airplanes or cars is that products like dynamat are designed and are very good at reducing panel resonation, and not so much at reducing heat transfer. You actually don't even need to cover the entire surface, just use enough to stop the resonation of the panels. For best sound deadening, heat and fume rejection, you must use a double sided foil covered insulating blanket type material on top of it. I get mine from Speedway Motors. Its very reasonably priced there. I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fum SPEEDWAY INSULATION LINK ?e rejection this technique provides. I learned how to do it this way reading about how they insulate small planes. Is this the product your referring to (See LINK)? SPEEDWAY INSUALTION LINKY
[Re: TJP]
#2958487
08/28/21 09:47 PM
08/28/21 09:47 PM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Killmat from Amazon is a good product and half the cost of the other name brand types.
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: Plum440]
#2958514
08/28/21 11:42 PM
08/28/21 11:42 PM
Posts: 10,672 Freeport IL USA
poorboy
Freeport IL USA
Killmat from Amazon is a good product and half the cost of the other name brand types. IIf you don't mind seeing their name spread all across the stuff. If you don't want to see advertising, NOICO is only a buck or so higher in silver, or another buck higher in black. I've used the .080 thickness in black, on 3 vehicles now. It sticks well to the metal, and isn't bad to work with, as long as the area isn't too confined. You have to roll it out with a roller to complete the job, sand that hand held roller is 1" in diameter. For heat insulation, you need to cover every inch of the metal surface. If the OP is just covering the areas under the seat, none of that stuff will be an effective heat barrier. Vibration, yes, heat barrier, nope. For the guy asking about weight, a 36 SQ Ft package of NOICO weighs somewhere around 17 lbs. I have 2 packages of the .080 36 SQ FT packages inside of the cab of my 49 Dodge truck, everything is covered except the inside of the doors. There was not enough material to cover the insides of both doors, and getting that stuff inside of those doors would have been a huge challenge. Picture of the truck for cab size reference. Gene.
![Name: 100_0676.JPG
ID: 435774 100_0676.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/435774/filename/100_0676.JPG)
[Re: poorboy]
#2958576
08/29/21 08:05 AM
08/29/21 08:05 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
If I may ask a question, I can't help but wonder if i were to put it on the underside of my roof (i'm just weeks away from cloth headliner replacement on my 1970 Swinger build) with a cloth headliner, that sitting in the South Florida sun, it would take about a half hour and it would drip down through onto my head and interior possibly ruining everything! Please advise with actual first hand experience. Thanks Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: TJP]
#2958577
08/29/21 08:07 AM
08/29/21 08:07 AM
jbc426
West Coast, USA
I've done with both my cars and my truck with Dynamat Extreme in bulk packs. I found it on sale on Amazon for about 1/2 off with free shipping. It is heavy. I do two layers on the wheel tubs, and one the entire floor, ceiling and doors(some strips inside and on the panel). The key to insulating airplanes or cars is that products like dynamat are designed and are very good at reducing panel resonation, and not so much at reducing heat transfer. You actually don't even need to cover the entire surface, just use enough to stop the resonation of the panels. For best sound deadening, heat and fume rejection, you must use a double sided foil covered insulating blanket type material on top of it. I get mine from Speedway Motors. Its very reasonably priced there. I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fum SPEEDWAY INSULATION LINK ?e rejection this technique provides. I learned how to do it this way reading about how they insulate small planes. Is this the product your referring to (See LINK)? SPEEDWAY INSUALTION LINKY Yes, that is it.
[Re: Sniper]
#2958578
08/29/21 08:11 AM
08/29/21 08:11 AM
jbc426
West Coast, USA
I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fume rejection this technique provides. I learned how to do it this way reading about how they insulate small planes. I cannot begin to imagine how much added weight that is. It adds 15lbs for each full bulk pack of Dynamat Extreme.. I used 3 packs on my '70 E-Body, The foil insulator adds a couple pounds too.
[Re: jbc426]
#2958592
08/29/21 09:20 AM
08/29/21 09:20 AM
Sniper
nowhere
I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fume rejection this technique provides. I learned how to do it this way reading about how they insulate small planes. I cannot begin to imagine how much added weight that is. It adds 15lbs for each full bulk pack of Dynamat Extreme.. I used 3 packs on my '70 E-Body, The foil insulator adds a couple pounds too. Thanks, I think what was confusing me was the cocooning statement. Didn't realize that it was foil backed jute you were referring to in that statement. I had thought it was all Dynamat, lol.
[Re: Copper Dart]
#2958676
08/29/21 01:14 PM
08/29/21 01:14 PM
Posts: 21,542 It's a dry heat
gtx6970
It's a dry heat
If I may ask a question, I can't help but wonder if i were to put it on the underside of my roof (i'm just weeks away from cloth headliner replacement on my 1970 Swinger build) with a cloth headliner, that sitting in the South Florida sun, it would take about a half hour and it would drip down through onto my head and interior possibly ruining everything! Please advise with actual first hand experience. Thanks Copper I used fatmat in the roof of an E body in place of the OEM insulation. The car is also a black vinyl top car as well. No funky smells or drips in the headliner of any kind. And that car is going on being done maybe 7 or 8 years now I guess ,,,maybe more I want to cool the interior down in my car . Radiant heat out here is a mother I just ordered a 50 sqft roll of 080 fatmat for it. Im going to cover the floorboards from the base of the steering column and heater box all the way back under the rear seat .
