OEM spec 426 HEMI torque converter #2956596
08/23/21 01:53 PM
08/23/21 01:53 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
Looking to see if anyone has recently dealt with getting a torque converter for their 426 Hemi / auto mopar. I'm working on a '69 Dodge Charger 500 426 HEMI car. I'd like to deal with someone/firm that deals with this on a regular basis.... Haven't had to buy a Hemi torque converter in a LONG time.. I know there's the external balancing to consider..
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: OEM spec 426 HEMI torque converter [Re: hemi68charger] #2956743
08/23/21 09:05 PM
08/23/21 09:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
Huh ??? to my knowledge hemis were internally balanced twocents shruggy beer
Re: OEM spec 426 HEMI torque converter [Re: TJP] #2956763
08/23/21 09:38 PM
08/23/21 09:38 PM
Originally Posted by TJP
Quote
iagree
None of the 426 hemi motors made by Mopar, street or race hemi, where external balanced tsk
Same on all the early Hemi motors in all brands of Mopars made before 1959 scope
OP, are you talking about some of Gen 3 late model hemiroid motors ? confused
Re: OEM spec 426 HEMI torque converter [Re: Cab_Burge] #2956772
08/23/21 10:01 PM
08/23/21 10:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Nothing special about Street Hemi verts other than big bolts on the flex plate, just a 11” like the 383-340 hypos got, maybe a little more stall. Still have my 68 Charger one
Re: OEM spec 426 HEMI torque converter [Re: Cab_Burge] #2956822
08/24/21 07:06 AM
08/24/21 07:06 AM
Houston, Tx
Houston, Tx
Quote
iagree
Hey Cab,,
So, I don't need to worry about balancing weights like what was on the 6bbl motors? I know 6bbls has weights on them........ So I just need to consider the larger lugs and what stall I want? If so, that makes things easier......
Troy
Re: OEM spec 426 HEMI torque converter [Re: hemi68charger] #2956858
08/24/21 09:41 AM
08/24/21 09:41 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Were there any 440's with an 11" vert?
I thought all 440-s came with 12", even 3- 2s.
Joe
Re: OEM spec 426 HEMI torque converter [Re: jlatessa] #2956875
08/24/21 10:26 AM
08/24/21 10:26 AM
NJ
cb1289 Offline
cb1289  Offline
NJ
Just call Paul at Turbo Action. He will answer all your questions and set you up with a good converter .904 741 4850
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: OEM spec 426 HEMI torque converter [Re: cb1289] #2956914
08/24/21 12:07 PM
08/24/21 12:07 PM
Houston, Tx
Houston, Tx
thanks... That number doesn't work.. Will try to connect via email........
Troy
Re: OEM spec 426 HEMI torque converter [Re: hemi68charger] #2957029
08/24/21 06:39 PM
08/24/21 06:39 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Troy,
I also went with a Turbo Action Hemi Torque converter (model #17501). This was pretty much a stock build 426 for my 68 Road Runner. I really like how it feels and would use it again.
https://youtu.be/l-bhI1FDUWE
Re: OEM spec 426 HEMI torque converter [Re: 68jim] #2957090
08/24/21 09:55 PM
08/24/21 09:55 PM
Houston, Tx
Houston, Tx
Originally Posted by 68jim
Troy,
Nice !!! I will try to call them again in the morning...... Hopefully the phone number works this time... Nice looking and sounding Runner !!!
Troy
Re: OEM spec 426 HEMI torque converter [Re: hemi68charger] #2957102
08/24/21 10:23 PM
08/24/21 10:23 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Message sent.
Re: OEM spec 426 HEMI torque converter [Re: jlatessa] #2957264
08/25/21 12:53 PM
08/25/21 12:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Joe
Starting in '73 the 11" converter became available on select forged-crank 440's.... the same converter as the /6, 318 and 340.
