OEM spec 426 HEMI torque converter
#2956596
08/23/21 01:53 PM
08/23/21 01:53 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Hello All,
Looking to see if anyone has recently dealt with getting a torque converter for their 426 Hemi / auto mopar. I'm working on a '69 Dodge Charger 500 426 HEMI car. I'd like to deal with someone/firm that deals with this on a regular basis.... Haven't had to buy a Hemi torque converter in a LONG time.. I know there's the external balancing to consider..
Thanks.. Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: OEM spec 426 HEMI torque converter
[Re: TJP]
#2956763
08/23/21 09:38 PM
08/23/21 09:38 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I know there's the external balancing to consider.. Huh ??? to my knowledge hemis were internally balanced None of the 426 hemi motors made by Mopar, street or race hemi, where external balanced Same on all the early Hemi motors in all brands of Mopars made before 1959 OP, are you talking about some of Gen 3 late model hemiroid motors ?
[Re: Cab_Burge]
#2956822
08/24/21 07:06 AM
08/24/21 07:06 AM
hemi68charger
Houston, Tx
I know there's the external balancing to consider.. Huh ??? to my knowledge hemis were internally balanced ... Hey Cab,, So, I don't need to worry about balancing weights like what was on the 6bbl motors? I know 6bbls has weights on them........ So I just need to consider the larger lugs and what stall I want? If so, that makes things easier......
[Re: jlatessa]
#2956875
08/24/21 10:26 AM
08/24/21 10:26 AM
Posts: 145 NJ
cb1289
NJ
Just call Paul at Turbo Action. He will answer all your questions and set you up with a good converter .904 741 4850
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#2956914
08/24/21 12:07 PM
08/24/21 12:07 PM
hemi68charger
Houston, Tx
Just call Paul at Turbo Action. He will answer all your questions and set you up with a good converter .904 741 4850 thanks... That number doesn't work.. Will try to connect via email........
[Re: 68jim]
#2957090
08/24/21 09:55 PM
08/24/21 09:55 PM
hemi68charger
Houston, Tx
Troy, I also went with a Turbo Action Hemi Torque converter (model #17501). This was pretty much a stock build 426 for my 68 Road Runner. I really like how it feels and would use it again. https://youtu.be/l-bhI1FDUWE Nice !!! I will try to call them again in the morning...... Hopefully the phone number works this time... Nice looking and sounding Runner !!!
[Re: jlatessa]
#2957264
08/25/21 12:53 PM
08/25/21 12:53 PM
Posts: 25,754 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Were there any 440's with an 11" vert? I thought all 440-s came with 12", even 3- 2s.
Joe Starting in '73 the 11" converter became available on select forged-crank 440's.... the same converter as the /6, 318 and 340.
