aluminum head repairs
#2953987
08/15/21 01:04 PM
08/15/21 01:04 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: aluminum head repairs
[Re: J_BODY]
#2953993
08/15/21 01:28 PM
08/15/21 01:28 PM
68LAR
South Park, Pa.
Some can…. Some can’t. If you have a W5, I’ll just say…. Good luck! That said one of my W8 heads had a combustion chamber repair done prior to me owning them. Looked like new. RB RPM head
[Re: 68LAR]
#2954044
08/15/21 03:26 PM
08/15/21 03:26 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
All can be welded. Not all should be fixed.
[Re: 68LAR]
#2954056
08/15/21 04:02 PM
08/15/21 04:02 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers Pretty common problem(probably the most common aluminum head welding repair). Somebody fairly close to you should be able to take care of it.
[Re: fast68plymouth]
#2954075
08/15/21 06:27 PM
08/15/21 06:27 PM
68LAR
South Park, Pa.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers Pretty common problem(probably the most common aluminum head welding repair). Somebody fairly close to you should be able to take care of it. . Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again.
[Re: 68LAR]
#2954090
08/15/21 07:17 PM
08/15/21 07:17 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers Pretty common problem(probably the most common aluminum head welding repair). Somebody fairly close to you should be able to take care of it. . Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again. I’m sure Tom Hemphill could fix you up but I’m not sure how long it would take. An old timer down by pittsburgh mills mall could probably do it in a day or two. Let me know if you need his number. He can’t machine it but he could weld it. This guy has some interesting history and stories to tell
[Re: pittsburghracer]
#2954096
08/15/21 07:26 PM
08/15/21 07:26 PM
68LAR
South Park, Pa.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers Pretty common problem(probably the most common aluminum head welding repair). Somebody fairly close to you should be able to take care of it. . Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again. I’m sure Tom Hemphill could fix you up but I’m not sure how long it would take. An old timer down by pittsburgh mills mall could probably do it in a day or two. Let me know if you need his number. He can’t machine it but he could weld it. This guy has some interesting history and stories to tell . If you could, send me any contact info you have. PM me. I’d like to find a one stop shopping place, I’ll take anything at this point. This will be my first rodeo.
[Re: 340Cuda]
#2954219
08/16/21 10:48 AM
08/16/21 10:48 AM
Posts: 1,073 oregon
greendart408
oregon
Mike Lane at FastLane Machine in Orem Utah fixed a W9 of mine that had chamber messed up. Looking at it now I can't tell which one it was. He used to work for Chapman. http://fastlanemachineinc.com/ I second this, had on 2 occasions now a lifting the head issue on my f2 w8 stuff. Sent them here to have the 3/4in deep fire torch issue fixed. MINT work.
[Re: 68LAR]
#2954272
08/16/21 01:12 PM
08/16/21 01:12 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hey Larry There is a one stop shop in Akron where I get some of my stuff machined. They repair big diesel heads and complete the valve job when finished with the repairs. Center Automotive in Akron Ohio talk to Randy he is the man in charge. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68LAR]
#2954274
08/16/21 01:23 PM
08/16/21 01:23 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My welder says pre-heating is the key to a successful aluminum head repair weld.
[Re: John_Kunkel]
#2954331
08/16/21 03:35 PM
08/16/21 03:35 PM
68LAR
South Park, Pa.
I just dropped off the head for welding and machine work. Thanks to everyone for your input. Hopefully I'll have it back by the end of the week.
[Re: 68LAR]
#2954336
08/16/21 03:45 PM
08/16/21 03:45 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just dropped off the head for welding and machine work. Thanks to everyone for your input. Hopefully I'll have it back by the end of the week. Where did you end up going.
#2954338
08/16/21 03:53 PM
08/16/21 03:53 PM
68LAR
South Park, Pa.
Tom Hemphill's . Thanks for the connection. He is pretty far from my house, but it is a one stop deal.
[Re: 68LAR]
#2954347
08/16/21 04:21 PM
08/16/21 04:21 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Tom Hemphill's . Thanks for the connection. He is pretty far from my house, but it is a one stop deal. Glad it worked out for you.
[Re: John_Kunkel]
#2954355
08/16/21 04:38 PM
08/16/21 04:38 PM
Posts: 201 Texas
Chief
Texas
My welder says pre-heating is the key to a successful aluminum head repair weld. I would add grind it with a carbide till it has no contamination in the damaged area then weld it. Dave
Dave Covey
