aluminum head repairs #2953987
08/15/21 01:04 PM
08/15/21 01:04 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: aluminum head repairs [Re: 68LAR] #2953992
08/15/21 01:22 PM
08/15/21 01:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Some can…. Some can’t. If you have a W5, I’ll just say…. Good luck!
That said one of my W8 heads had a combustion chamber repair done prior to me owning them. Looked like new.
Re: aluminum head repairs [Re: J_BODY] #2953993
08/15/21 01:28 PM
08/15/21 01:28 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
RB RPM head
Re: aluminum head repairs [Re: 68LAR] #2954004
08/15/21 01:47 PM
08/15/21 01:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
Take it to a good aircraft repair shop(tig welds aluminum) and see if they will work on it for you scope
or a heavy duty diesel repair shop also scope
Re: aluminum head repairs [Re: 68LAR] #2954044
08/15/21 03:26 PM
08/15/21 03:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
All can be welded. Not all should be fixed.
Re: aluminum head repairs [Re: 68LAR] #2954056
08/15/21 04:02 PM
08/15/21 04:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Pretty common problem(probably the most common aluminum head welding repair).
Somebody fairly close to you should be able to take care of it.
Re: aluminum head repairs [Re: fast68plymouth] #2954075
08/15/21 06:27 PM
08/15/21 06:27 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
. Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again.
Re: aluminum head repairs [Re: 68LAR] #2954090
08/15/21 07:17 PM
08/15/21 07:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m sure Tom Hemphill could fix you up but I’m not sure how long it would take. An old timer down by pittsburgh mills mall could probably do it in a day or two. Let me know if you need his number. He can’t machine it but he could weld it. This guy has some interesting history and stories to tell
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: aluminum head repairs [Re: pittsburghracer] #2954096
08/15/21 07:26 PM
08/15/21 07:26 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
. If you could, send me any contact info you have. PM me. I’d like to find a one stop shopping place, I’ll take anything at this point. This will be my first rodeo.
Re: aluminum head repairs [Re: 68LAR] #2954099
08/15/21 07:53 PM
08/15/21 07:53 PM
PA.
"Little"John
"Little"John
PA.
I sent you a message with a couple of numbers. My son works for this guy at a chassis shop in Even City. The owner could probably weld it but not machine it.
http://www.findglocal.com/US/Evans-City/245330545868189/Cage-Rage-Fabrication-LLC
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum head repairs [Re: pittsburghracer] #2954208
08/16/21 10:31 AM
08/16/21 10:31 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Mike Lane at FastLane Machine in Orem Utah fixed a W9 of mine that had chamber messed up.
Looking at it now I can't tell which one it was.
He used to work for Chapman.
http://fastlanemachineinc.com/
Re: aluminum head repairs [Re: 340Cuda] #2954219
08/16/21 10:48 AM
08/16/21 10:48 AM
oregon
greendart408 Offline
oregon
I second this, had on 2 occasions now a lifting the head issue on my f2 w8 stuff. Sent them here to have the 3/4in deep fire torch issue fixed. MINT work.
Re: aluminum head repairs [Re: 68LAR] #2954272
08/16/21 01:12 PM
08/16/21 01:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hey Larry
There is a one stop shop in Akron where I get some of my stuff machined. They repair big diesel heads and complete the valve job when finished with the repairs.
Center Automotive in Akron Ohio talk to Randy he is the man in charge.
Gus beer
64 Plymouth Savoy
Dana 60
Re: aluminum head repairs [Re: 68LAR] #2954274
08/16/21 01:23 PM
08/16/21 01:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My welder says pre-heating is the key to a successful aluminum head repair weld.
Re: aluminum head repairs [Re: John_Kunkel] #2954331
08/16/21 03:35 PM
08/16/21 03:35 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I just dropped off the head for welding and machine work. Thanks to everyone for your input. Hopefully I'll have it back by the end of the week.
Re: aluminum head repairs [Re: 68LAR] #2954336
08/16/21 03:45 PM
08/16/21 03:45 PM
PA.
"Little"John
"Little"John
PA.
Where did you end up going.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum head repairs [Re: pittsburghracer] #2954338
08/16/21 03:53 PM
08/16/21 03:53 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Tom Hemphill's . Thanks for the connection. He is pretty far from my house, but it is a one stop deal.
Re: aluminum head repairs [Re: 68LAR] #2954347
08/16/21 04:21 PM
08/16/21 04:21 PM
PA.
"Little"John
"Little"John
PA.
Glad it worked out for you.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum head repairs [Re: John_Kunkel] #2954355
08/16/21 04:38 PM
08/16/21 04:38 PM
Texas
Chief Offline
Chief  Offline
Texas
I would add grind it with a carbide till it has no contamination in the damaged area then weld it.
Dave Covey
