Re: MP Distributor Pickup gap
[Re: RapidRobert]
#295370
04/22/09 11:34 AM
04/22/09 11:34 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Can you borrow a light & see where your timing is
He mentioned that it has a miss-matched balancer and timing cover, so would think a light on it wouldn't help ?
[Re: RapidRobert]
#295372
04/22/09 11:48 AM
04/22/09 11:48 AM
OzHemi
Garden Grove, CA
As is no but I was assuming that he would get that taken care of & to know where his timing is at is crucial
It sure would make it handy to check the timing, yep.
Even making a TDC mark on the other side, then using a dial back timing light would help (did that once before myself)
[Re: OzHemi]
#295373
04/22/09 11:57 AM
04/22/09 11:57 AM
RapidRobert
I check every eng I work with w a TDC stop tool to see if the factory marks are spot on & though I've never seen one more than 1 degree off I dont assume anything(almost ).
[Re: 68Fastback]
#295375
04/22/09 03:26 PM
04/22/09 03:26 PM
RapidRobert
Rotor phasing: If the rotor tip gets far enough away from it's terminal on the underside of the dist cap the spark wont make it everytime & it'll effect a miss. a combination of initial timing/mech adv/vac adv and or a slight machining error in any one of these, cap/rotor/adv plate/reluctor can cause a stackup of tolerances. I drill a 3/8" hole in my dist cap in the flat top part in between the center terminal & the #1 terminal so that I can see the rotor & I freeze it w my timing light at the offending rpm & see how close the rotor metal blade is pointing to the center of the #1 plug terminal. Or adv and retard your initial 5 to 10 degrees from where it is now & see if that affects the miss as one of those 2 actions(adv or retard) will put the rotor tip closer to the bottom of the dist cap terminal.
[Re: 68Fastback]
#295377
04/24/09 02:07 AM
04/24/09 02:07 AM
OzHemi
Garden Grove, CA
What do you mean freeze it ?
The timing light to freeze it in place, like you do with the timing mark on the balancer I assume he means. (to see what it lines up with..)
Either that, or it's some sort of lingo
[Re: RapidRobert]
#295380
04/24/09 07:20 PM
04/24/09 07:20 PM
Challenger 1
Cincinnati, Ohio
[Re: Challenger 1]
#295381
04/24/09 07:37 PM
04/24/09 07:37 PM
OzHemi
Garden Grove, CA
That makes your car run faster too..it lets all the electro-molecules air out and not bunch up in the distributor, which slows you down.
[Re: 68Fastback]
#295384
04/24/09 11:43 PM
04/24/09 11:43 PM
RapidRobert
you might change your initial 10 degrees both ways from where it is now & see if that affects the miss or plugging the vac adv & trying it which would change it in one direction but it's be real fast/easy to do. & your plugs/wires ARE good?
[Re: REDNICK]
#295388
05/01/09 11:43 AM
05/01/09 11:43 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
phasing is easy like check the rotation direction arrows on reluctor and set the pin guide to the dist shaft correctly.
Note about the gap... CHECK IT ALSO WITH VACUUM in PULLING position. Since ratious center of pick up and center of disttributor are TOTALLY DIFFERENT, then the circuference set by pick up never will meet the reluctor circunference. If you set the gap too close on rest positiomn, when vacuum is pulling in, the pick up will BITE THE RELUCTOR.
In my experience ( and I have tried everything bending here and there, milling here and there ) try to set the gap between 9-10 hundreds on rest position, and you'll get between 7-8 hundreds on vaccuum pulling position.
I definitelly set it on 9 to get 7
