Re: LM-2 burned a resistor inside 3 months old.
[Re: Clanton]
#2951105
08/06/21 03:42 PM
08/06/21 03:42 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Looks like a ceramic capacitor to me............
[Re: Clanton]
#2951107
08/06/21 03:43 PM
08/06/21 03:43 PM
Posts: 2,933 A shed in England
Tig
A shed in England
That's a Tantalum capacitor, they are polarity conscious.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2951111
08/06/21 03:49 PM
08/06/21 03:49 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
That's a Tantalum capacitor, they are polarity conscious. I was using the cigarette lighter power adaptor so IDK if it can get shorted inside.
[Re: Clanton]
#2951282
08/07/21 06:21 AM
08/07/21 06:21 AM
Tig
A shed in England
That's a Tantalum capacitor, they are polarity conscious. I was using the cigarette lighter power adaptor so IDK if it can get shorted inside. Is the top, two pin dark coloured block the I/P for the power supply? (I'm guessing it is since it's the only two pin socket). You may need to check the polarity of your cig lighter. Something tells me in the dark recesses of my mind, that they are wired reverse to what most manufacturers of cig lighter PSU adapters expect. But I could be wrong . It's worth checking. HTH's
[Re: Tig]
#2951301
08/07/21 09:30 AM
08/07/21 09:30 AM
Posts: 143 North America
kwikblownhemi
North America
That's a Tantalum capacitor, they are polarity conscious. I was using the cigarette lighter power adaptor so IDK if it can get shorted inside. Is the top, two pin dark coloured block the I/P for the power supply? (I'm guessing it is since it's the only two pin socket). You may need to check the polarity of your cig lighter. Something tells me in the dark recesses of my mind, that they are wired reverse to what most manufacturers of cig lighter PSU adapters expect. But I could be wrong . It's worth checking. HTH's You are correct, it's labelled Power. Interesting that there appears to be a reverse-polarity protection diode beside it. If the OP has been using the same cigarette lighter plug for three months, it probably isn't a case of reverse polarity. That capacitor, along with two others, a jumper and a resistor are post-production modifications.
[Re: kwikblownhemi]
#2951329
08/07/21 10:56 AM
08/07/21 10:56 AM
Clanton
northern,Ohio,USA
That's a Tantalum capacitor, they are polarity conscious. I was using the cigarette lighter power adaptor so IDK if it can get shorted inside. Is the top, two pin dark coloured block the I/P for the power supply? (I'm guessing it is since it's the only two pin socket). You may need to check the polarity of your cig lighter. Something tells me in the dark recesses of my mind, that they are wired reverse to what most manufacturers of cig lighter PSU adapters expect. But I could be wrong . It's worth checking. HTH's You are correct, it's labelled Power. Interesting that there appears to be a reverse-polarity protection diode beside it. If the OP has been using the same cigarette lighter plug for three months, it probably isn't a case of reverse polarity. That capacitor, along with two others, a jumper and a resistor are post-production modifications. I have been using the same power port without trouble and yes the left plug is power but is a 4 prong.
