LM-2 burned a resistor inside 3 months old. #2951099
08/06/21 03:31 PM
08/06/21 03:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I was just warming the car in the garage checking things and sparks came from the scanner tool part and I opened it up and a resistor had exploded.There may be more wrong with the tool but I am sending it in to be fixed and find out.You guys that have this tool may run into this problem or have had this problem.The resistor may only cost .50cents.
Re: LM-2 burned a resistor inside 3 months old. [Re: Clanton] #2951105
08/06/21 03:42 PM
08/06/21 03:42 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Looks like a ceramic capacitor to me............
Re: LM-2 burned a resistor inside 3 months old. [Re: Clanton] #2951107
08/06/21 03:43 PM
08/06/21 03:43 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
That's a Tantalum capacitor, they are polarity conscious.
Re: LM-2 burned a resistor inside 3 months old. [Re: Tig] #2951111
08/06/21 03:49 PM
08/06/21 03:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I was using the cigarette lighter power adaptor so IDK if it can get shorted inside.
Re: LM-2 burned a resistor inside 3 months old. [Re: Clanton] #2951126
08/06/21 04:59 PM
08/06/21 04:59 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I bought a LM-2 to use for my 66 coronet. I had one O2 sensor that would not work right off the bat, so I called summit and they said it had a one year warranty.
I just sent the old one back and they sent a new one out. I have not used it yet but hopefully all goes well with it.
Matt
Re: LM-2 burned a resistor inside 3 months old. [Re: mattsmopars] #2951174
08/06/21 07:15 PM
08/06/21 07:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I could drive there to summit in 45 minutes but I don't need any other parts or in a hurry.I hope yours is good for a long time using it.
Re: LM-2 burned a resistor inside 3 months old. [Re: Clanton] #2951282
08/07/21 06:21 AM
08/07/21 06:21 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Is the top, two pin dark coloured block the I/P for the power supply? (I'm guessing it is since it's the only two pin socket). You may need to check the polarity of your cig lighter.
Something tells me in the dark recesses of my mind, that they are wired reverse to what most manufacturers of cig lighter PSU adapters expect. But I could be wrong shruggy.
It's worth checking. HTH's up
Re: LM-2 burned a resistor inside 3 months old. [Re: Tig] #2951301
08/07/21 09:30 AM
08/07/21 09:30 AM
North America
K
kwikblownhemi Offline
K
North America
You are correct, it's labelled Power. Interesting that there appears to be a reverse-polarity protection diode beside it. If the OP has been using the same cigarette lighter plug for three months, it probably isn't a case of reverse polarity.
That capacitor, along with two others, a jumper and a resistor are post-production modifications.
Re: LM-2 burned a resistor inside 3 months old. [Re: kwikblownhemi] #2951329
08/07/21 10:56 AM
08/07/21 10:56 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have been using the same power port without trouble and yes the left plug is power but is a 4 prong.
Re: LM-2 burned a resistor inside 3 months old. [Re: Clanton] #2956100
08/21/21 07:13 PM
08/21/21 07:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got a new LM-2 replacement free from Auto Meter in the mail today.
