Need a rear end ... #2948671
07/29/21 09:11 PM
07/29/21 09:11 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Need a complete new rear end.
2" Mini-tubbed '69 RR.
Want:
- Dana
- 3:54 gears
- disc brakes
- would like to install ABS so need the sensor ring in the rear end
What's a good street diff - posi, Detroit Locker, Detroit TruTrac or Trac-Loc
What's a good rear disc setup - want something that you can easily find parts for. Strange offers "Explorer" rear setup. Others offer "economy" etc.
Looked at Dr. Diff, Strange, Moser and DTS
Dr Diff is out west so shipping would be expensive. DTS is within driving distance (when the borders open). Strange doesn't have an online shopping/price list.
Also, as far as rear end fitment/width, what's a respectable amount of clearance between the tire and inner tub (Caltrac mono-leafs).
I'm considering just ordering a stock width rear end and use a wheel with 2" more backspacing
Re: Need a rear end ... [Re: Stanton] #2948799
07/30/21 11:43 AM
07/30/21 11:43 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Has ABS on a non floating axle Dana 60 been done? Are there parts or kits available to do this or are you going to design and fabricate your own? Are there parts for the front? What about computer, master cylinder? Can it work with way different size tires front to back? (Minitubbed and wide wheels and tires) Unless there is a well engineered complete kit for this you better really really know what you are doing.
Re: Need a rear end ... [Re: Stanton] #2948803
07/30/21 11:48 AM
07/30/21 11:48 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I've had both a spool and a Detroit in street vehicles, and I wouldn't recommend either on the street. The spool was ridiculous. The Detroit was never a big problem, but was more than a little annoying when it would engage while turning. Very harsh.
Earning every penny of that moderator paycheck.
DBAP
Re: Need a rear end ... [Re: not_a_charger] #2948828
07/30/21 01:26 PM
07/30/21 01:26 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A Tru-Trac or Wavelock diff is probably your best option.
One thing I like about a spool is predictability, you always know exactly how it will act because it can only do one thing and that is keep the tires locked together. A locker is a spool, or its not, and the times it decides to come in and out of the locked status don't always make sense.
In the rain I am fully aware of how my Barracuda acts with a spool, its really no big deal because I know exactly what it will do which is usually nothing out of the ordinary. My Jeep has a locker and it's not always predictable, when it locks and unlocks usually is but how the vehicle responds is not.
68 Barracuda Formula S 340
Re: Need a rear end ... [Re: Bad340fish] #2948843
07/30/21 01:55 PM
07/30/21 01:55 PM
I agree with all of that. I hated the spool, but I knew what to expect. The locker would bite me on occasion, even if I was aware of what might happen. My Jeep had a 7 inch lift, 35s, etc, so when that locker would lock during a turn, it would hit hard.
DBAP
Re: Need a rear end ... [Re: not_a_charger] #2949055
07/31/21 08:04 AM
07/31/21 08:04 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
ABS in a 69??? More info on motor trans/details would help. You can get 9 1/4's with both ABS ring and disk brakes out of later model dodge pick ups.
Re: Need a rear end ... [Re: GomangoCuda] #2949098
07/31/21 11:09 AM
07/31/21 11:09 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Not sure on that, they did a 248 rbi axle that everyone calls a dana 60 with a trac-loc and the exciter ring, not sure on axle splines, or if it is a weird dana version or 9-1/4 as the service manual shows 3.55 gears, not the traditional 3
54. They also did a dana 70 with the powerlock and the ring that could be gear swapped to 35 spline axles. A guy would need to know if the ring and sensor are compatible before spending any money.
Re: Need a rear end ... [Re: Stanton] #2949109
07/31/21 11:37 AM
07/31/21 11:37 AM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=Stanton]Need a complete new rear end.
Unit will ship from Strange in Chicago,
Re: Need a rear end ... [Re: Stanton] #2949160
07/31/21 02:09 PM
07/31/21 02:09 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Rick Ehrenberg had an article in Mopar Action about retrofitting rear ABS using components from the old B series vans.
Re: Need a rear end ... [Re: mgoblue9798] #2949331
08/01/21 09:38 AM
08/01/21 09:38 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Yup, that's the plan.
Also thinking of using the Mopar 9-1/4 rear end as well a the Jeep rear disc swap (if they'll work on the 9-1/4). I like the idea of keeping it all "Mopar" and off-the-shelf parts.
Re: Need a rear end ... [Re: Stanton] #2949342
08/01/21 10:25 AM
08/01/21 10:25 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Have you got a price from DTS? I looked on their site and they want $5000 for a D 60...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Need a rear end ... [Re: Stanton] #2949346
08/01/21 10:40 AM
08/01/21 10:40 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
I got my dana from dr diff a few months back and the shipping was included in the price which by the way was a good deal.
Re: Need a rear end ... [Re: Stanton] #2949408
08/01/21 02:20 PM
08/01/21 02:20 PM
moparx Offline
moparx  Offline
Originally Posted by Stanton
Quote
i'm pretty sure the 9 1/4" rear has the same axle stand off measurement and bolt pattern as the 8 3/4, so the brake swap should work out.
beer
Re: Need a rear end ... [Re: moparx] #2949426
08/01/21 03:30 PM
08/01/21 03:30 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I would have to find my receipts to be exact, but I think I've got $2700 into my D60. Bought the axle off of Craigslist for $100 and reused the ring gear as it was in good shape and the ratio I wanted. Bought everything else from Doctor Diff and had Warren Gear and Axle assemble it all. Included an Explorer rear disc setup.
Re: Need a rear end ... [Re: MarkZ] #2949429
08/01/21 03:36 PM
08/01/21 03:36 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I spec'd mine out with Dr Diff and it comes to $2,690.00,
Unfortunately I didn't order it last week and they're closed until Aug 9th for vacation now, Looks like the Dream Cruise and probably Hines Drive is out, again...
Doug
Re: Need a rear end ... [Re: Stanton] #2949463
08/01/21 05:17 PM
08/01/21 05:17 PM
AndyF Online content
AndyF  Online Content
I sold the S60 out of my Duster last month for $1900 complete with disc brakes. It had 4.10 gears and a Detroit Locker.
Re: Need a rear end ... [Re: Sledge_57] #2949464
08/01/21 05:18 PM
08/01/21 05:18 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Apparently the Explorer brakes don't fit in Weld ProStars as well as a few other popular wheels !!
Re: Need a rear end ... [Re: AndyF] #2949465
08/01/21 05:20 PM
08/01/21 05:20 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Yeah I saw that at the time but I think it was too narrow. There was some reason I wasn't all over it not the least being shipping and the border closure.
Re: Need a rear end ... [Re: Sledge_57] #2949483
08/01/21 06:19 PM
08/01/21 06:19 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Why don't you yank the axle out then and have Warren Gear go through what you have?
Re: Need a rear end ... [Re: MarkZ] #2949555
08/01/21 09:53 PM
08/01/21 09:53 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Never heard of Warren Gear before, calling tomorrow...
Doug
