Re: NOS 3843787 wiring fits what?
[Re: mopars4ever]
#2948856
07/30/21 02:34 PM
07/30/21 02:34 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
it is definitelly an underdash harness for some accesory. By the PN, seems tobe soemething between 74-78
[Re: mopars4ever]
#2948860
07/30/21 02:44 PM
07/30/21 02:44 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looks like a cruise control harness from late seventies to early eighties.
[Re: John_Kunkel]
#2949035
07/31/21 12:26 AM
07/31/21 12:26 AM
Posts: 13,593 md
mopars4ever
md
[Re: John_Kunkel]
#2949038
07/31/21 02:01 AM
07/31/21 02:01 AM
NachoRT74
Valencia, España
Cruise control doesn't require a wired ground source and this harness does.
[Re: NachoRT74]
#2949084
07/31/21 09:46 AM
07/31/21 09:46 AM
Posts: 18,421 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Cruise control doesn't require a wired ground source and this harness does. A cruise servo does require a ground. As I recall some were self grounded through the housing to the inner fender and the later servo's had a wire.
[Re: mopars4ever]
#2949165
07/31/21 02:27 PM
07/31/21 02:27 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
My 1981 Parts book does not show it...but the 1980 has a close hit, that being: 3843789, which is "WIRING, Inst. Panel", and shows up in the 14-1200/30 - "Speed Control H-N-F-G" section of that book.
[Re: NachoRT74]
#2949174
07/31/21 03:07 PM
07/31/21 03:07 PM
John_Kunkel
Rio Linda, CA
Cruise control doesn't require a wired ground source and this harness does. The later servos are plastic and require a ground wire.
[Re: John_Kunkel]
#2949242
07/31/21 08:49 PM
07/31/21 08:49 PM
Posts: 13,593 md
mopars4ever
md
Cruise control doesn't require a wired ground source and this harness does. The later servos are plastic and require a ground wire. makes sense thanks
[Re: mopars4ever]
#2949304
08/01/21 03:29 AM
08/01/21 03:29 AM
NachoRT74
Valencia, España
I didn't say it doesn't require a ground, but a wired ground
Yes, lates servos, but lates how lates? Definitelly not 70s which are the ones for this harness period by the PN ( and that's why I said that ), maybe 80s/90s.
This is definitely an underdash harness, but cruise control? dunno. I can't see the plug for the control switch which these harness get.
and those 90 degrees plugs, it seems to be for some cluster gauge stud...
Just thinking out loud.
