Sealing slicks with beadwork to hold air #2948507
07/29/21 12:32 PM
07/29/21 12:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Are Hoosiers better than M/Ts for holding air with doubleheader locks?
I usually spray permatex headliner adhesive inside to coat the walls.
Re: Sealing slicks with beadwork to hold air [Re: Sammy] #2948540
07/29/21 01:54 PM
07/29/21 01:54 PM
I remember when a lot of racers use dish soap to coat the insides of their slicks, I have done that but forgot about until seeing this post realcrazy
It worked but Hoosiers tubeless slicks do hold air a lot better than M/T tube types slicks due shruggy
My last set of 14/32 M/T stiff walls slicks held air fairly well when new, once they were worn to less than 1/2 the original tread depth they started loosing air quicker whiney shruggy
I ended up buying a new set of tubes for them and ran them until all the wear holes where gone up
Re: Sealing slicks with beadwork to hold air [Re: Cab_Burge] #2948544
07/29/21 02:10 PM
07/29/21 02:10 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks Cab. I'm running beadlocks so no tubes.
Going to try just using dishwasher soap 1st.
Re: Sealing slicks with beadwork to hold air [Re: Sammy] #2948574
07/29/21 03:55 PM
07/29/21 03:55 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think dishwashing soap was used to help mount tires,
I know I used it when I used to muscle motorcycle tires at home.
I use Permatex red spray adhesive for rim sealing on slicks.
This on a 727 equipped mostly street B-body.
Joe
Re: Sealing slicks with beadwork to hold air [Re: Sammy] #2948615
07/29/21 06:00 PM
07/29/21 06:00 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I've ran both and never had an issue with either, but I've only ever read MTs having that issue. No way I'd re-buy a tire I have to soap just to hold air, that's QC they should be doing on their end.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Sealing slicks with beadwork to hold air [Re: Sammy] #2948638
07/29/21 07:13 PM
07/29/21 07:13 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Not sure about Hoosier but my Phoenix tires with bead locks don't leak. I do have MT PBR's but not with beadlocks. They never loose any air either
Ok
Re: Sealing slicks with beadwork to hold air [Re: cudatom] #2948684
07/29/21 10:17 PM
07/29/21 10:17 PM
All the M/T bias ply slicks I've bought and used where design for tube per M/T tech and all the warehouses I've bought them from shruggy
Not so on the radials though, they are tubeless.
Hoosiers, Goodyear and maybe several others drag tire companies quit making tube type drag slicks years ago scope
Re: Sealing slicks with beadwork to hold air [Re: Cab_Burge] #2949345
08/01/21 10:40 AM
08/01/21 10:40 AM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
I’ve always used Dawn Liquid Blue I coat the entire insides and let dry Yes it’s a dripping mess but have had really good luck with Hoosiers I’m trying it out on Mickey Thompson because have heard they are prone to leaking down Randy
Re: Sealing slicks with beadwork to hold air [Re: CROWBAR] #2949365
08/01/21 11:40 AM
08/01/21 11:40 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Going to air up the new Hoosiers now and see if they drop down in air pressure over the next couple of days, before I mount them.
Re: Sealing slicks with beadwork to hold air [Re: Cab_Burge] #2949391
08/01/21 01:05 PM
08/01/21 01:05 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
Wipe the inside sidewalls of the slick with Dish soap.... one of life's happy little mystery's that doesn't cost much...and there is no good reason not to if your going tubeless.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Sealing slicks with beadwork to hold air [Re: W.I.N. Racing] #2949392
08/01/21 01:22 PM
08/01/21 01:22 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Not going to bubble balance them till I know they are sealed up.Damn Hoosiers get some serious sidewall depth to them..
