1985 w150 sliding rear window/ gasket #2947389
07/26/21 03:02 PM
07/26/21 03:02 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anybody have a picture of a factory sliding rear window for an 80s w150? Trying to determine if mine is original or aftermarket. Also, does anybody make a rear window gasket for one with the chrome trim that pushes in? I can only find replacements for aftermarket windows without the trim. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2947521
07/26/21 08:34 PM
07/26/21 08:34 PM
Guitar Jones Offline
Nobody makes the gasket for the factory slider.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1985 w150 sliding rear window/ gasket [Re: Guitar Jones] #2947585
07/26/21 10:33 PM
07/26/21 10:33 PM
clarks summit pa
clarks summit pa
Ok thanks. Are the gaskets that much different for the aftermarket sliders?
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2947759
07/27/21 12:07 PM
07/27/21 12:07 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
From what I remember yes. I can't remember and I haven't verified this but, I think someone used either both the slider and gasket for a 1994-1996 Ford F-150 application but, don't hold me to it as I'm uncertain. I thought I read it somewhere but, can't remember if it was even right.
Re: 1985 w150 sliding rear window/ gasket [Re: OrangeProwler] #2947783
07/27/21 01:15 PM
07/27/21 01:15 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
www.lmctruck.com doesn't make those?
Facts are stubborn things.
Re: 1985 w150 sliding rear window/ gasket [Re: larrymopar360] #2947846
07/27/21 04:26 PM
07/27/21 04:26 PM
You can get the aftermarket sliders and gaskets but not the gasket for the factory slider, went through that a couple years ago on my '92. That is why it has a regular rear window in it now and yeah, it's the same as some Ford application. I never used the slider anyway.
Re: 1985 w150 sliding rear window/ gasket [Re: larrymopar360] #2947870
07/27/21 05:47 PM
07/27/21 05:47 PM
clarks summit pa
clarks summit pa
Only for the standard rear windows and the aftermarket rear slider that they sell.
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2947883
07/27/21 06:31 PM
07/27/21 06:31 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
That's too bad. I just checked Ebay and no NOS ones right now.
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2948332
07/28/21 09:41 PM
07/28/21 09:41 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Are you looking for the rubber just for the sliding parts of the window, or the whole gasket? Reason I ask, is I used to have an 84 D350 with a solid glass, and a friend gave me a sliding rear window. I had a glass guy come swap it out, and he reused the same gasket that was around the perimeter opening. Of course, this was about 1990 when the truck wasn't very old.
Re: 1985 w150 sliding rear window/ gasket [Re: JDMopar] #2948798
07/30/21 11:27 AM
07/30/21 11:27 AM
clarks summit pa
clarks summit pa
Im looking for the whole gasket. Maybe I'll just try ordering a regular one then and give it a try.
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2948996
07/30/21 10:09 PM
07/30/21 10:09 PM
It won't work.
Re: 1985 w150 sliding rear window/ gasket [Re: Guitar Jones] #2949033
07/31/21 12:07 AM
07/31/21 12:07 AM
clarks summit pa
clarks summit pa
Ok
Re: 1985 w150 sliding rear window/ gasket [Re: Guitar Jones] #2949095
07/31/21 10:52 AM
07/31/21 10:52 AM
JDMopar Offline
JDMopar  Offline
Originally Posted by Guitar Jones
It won't work.
How come my old gasket in the 84 D350 worked? I know it was 100% the original gasket, cause I stood there and watched the guy swap the windows out in like 5 minutes. It never leaked a drop. Not arguing, just wondering. shruggy
Re: 1985 w150 sliding rear window/ gasket [Re: JDMopar] #2949103
07/31/21 11:22 AM
07/31/21 11:22 AM
5thAve Offline
5thAve  Offline
Aftermarket slider windows use the same gasket as glass. The factory slider windows fit differently and use a different gasket.
Re: 1985 w150 sliding rear window/ gasket [Re: 5thAve] #2949117
07/31/21 11:59 AM
07/31/21 11:59 AM
Middle of A Field
O
O
Middle of A Field
A lot of guys say to reuse the factory gasket if you're reinstalling the factory slider anyways[align:right][/align]. The last NOS gasket I saw for a 72-80 dodge truck sold for $200+ shipping about two years ago.
Re: 1985 w150 sliding rear window/ gasket [Re: OrangeProwler] #2949542
08/01/21 09:11 PM
08/01/21 09:11 PM
clarks summit pa
clarks summit pa
Does anyone have a picture of a factory slider? I believe mine is original, but I'm not positive
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2949553
08/01/21 09:52 PM
08/01/21 09:52 PM
Middle of A Field
O
O
Middle of A Field
Maybe someone could confirm but, this truck looks to have a factory rear slider.
https://www.purplewave.com/auction/...ps_and_Vans-1/2_Ton_Pickup_or_Van-Kansas
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2949562
08/01/21 10:35 PM
08/01/21 10:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why do you not just post the inside and outside pictures of your slider?
Re: 1985 w150 sliding rear window/ gasket [Re: NITROUSN] #2949573
08/02/21 12:26 AM
08/02/21 12:26 AM
5thAve Offline
5thAve  Offline
I don't know what the 80s ones look like but the older ones have bare aluminum frame and sit flat to the back of the cab. If it sticks out or if the top or sides are flat and don't match the window hole it's a pretty good sign it's aftermarket.
Re: 1985 w150 sliding rear window/ gasket [Re: NITROUSN] #2950085
08/03/21 05:06 PM
08/03/21 05:06 PM
clarks summit pa
clarks summit pa
I'll try, but I can never get pictures to work on a post.
