Page 1 of 3 1 2 3
1959 361ci. swap to 383 #2947064
07/25/21 06:30 PM
07/25/21 06:30 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Will a 1968, 383 directly replace a 1959 361 that is bolted to a push button automatic transmission? Was thinking it would work if the flywheels swapped.
Re: 1959 361ci. swap to 383 [Re: rapom] #2947066
07/25/21 06:33 PM
07/25/21 06:33 PM
Central NC
gch Offline
gch  Offline
Central NC
I don't see why not.They are both low deck big blocks.If I am missing something I am sure someone will let me know.
Re: 1959 361ci. swap to 383 [Re: gch] #2947075
07/25/21 07:06 PM
07/25/21 07:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I am not 100 percent sure but I believe there is a difference at the cranks rear flange.
Re: 1959 361ci. swap to 383 [Re: gch] #2947077
07/25/21 07:10 PM
07/25/21 07:10 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe up to 62, Mopar's had the extended crankshaft, the torque converters and flywheels had bolts that passed through the crankshaft flange and threaded into the converter or flywheel.
To install a modern (newer the 62) motor to replace an original I believe your going to need an adaptor between the crank and the torque converter or flywheel. Gene
Re: 1959 361ci. swap to 383 [Re: NITROUSN] #2947122
07/25/21 08:49 PM
07/25/21 08:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You are correct sir. The mating of the engine and trans prior to 1962 is completely different than 62 and later. Also different is the trans, cables/ control, driveshaft flange emergency brake etc. They did almost a 100% redesign of all mechanicals in 62. beer
Re: 1959 361ci. swap to 383 [Re: TJP] #2947130
07/25/21 09:03 PM
07/25/21 09:03 PM
iagree On both, been there done that more than once, use the later 727 and buy and use a decent floor shifter scope twocents
If you do this complete swap you will need to change the driveshaft also, Mopar use the old ball and trunion type front U joints in the automatic cars until 1965, they switch them on the stick shift cars in 1966. shruggy
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947147
07/25/21 09:43 PM
07/25/21 09:43 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thanks for the info everybody. Just trying to figure out all my options. And it looks like the easy option is not a option.🤔. I might be getting a car with a tired 361.
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947149
07/25/21 09:49 PM
07/25/21 09:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
iagree On both, been there done that more than once, use the later 727 and buy and use decent a floor shifter scope twocents
And a driveshaft and a different E brake setup. The list goes on.
Re: 1959 361ci. swap to 383 [Re: TJP] #2947153
07/25/21 09:55 PM
07/25/21 09:55 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
What about swapping the 361 crank in with a fresh polish, bearings and new rear main? Do the '68 heads and block have all the accessory mounting holes needed?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1959 361ci. swap to 383 [Re: 3hundred] #2947207
07/26/21 03:34 AM
07/26/21 03:34 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I like this. As far 361 crank comes great is a nice solution if you wanna get a 383 into your 59.
I guess you wanted to make a straight plug and play job without deal with engine dissasembling, but this would be a partial refreshing job on the 383.
I think some other stuff will be needed like keep the old 361 water pump and miscellaneous parts ( pulley, brackets ) to be installed into the 383.
Re: 1959 361ci. swap to 383 [Re: NachoRT74] #2947293
07/26/21 12:07 PM
07/26/21 12:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
To The OP, Trust me when I say swap the engine and trans both or not at all. beer
Re: 1959 361ci. swap to 383 [Re: 3hundred] #2947330
07/26/21 01:18 PM
07/26/21 01:18 PM
OP, if you do this crank swap make sure and have it balanced to the 383 piston and rod weights work twocents
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947376
07/26/21 02:24 PM
07/26/21 02:24 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Interesting options. I’m wondering if newer heads would work on the 361. I believe, the problem with the engine is with a valve in the head. Engine shakes bad at idle, but smoothes out at speed. Engine doesn’t burn any oil. Engine runs very quiet also, (no rod or lifter noises) There is gas in the clean oil. (Could be the fuel pump). Just noting what I observed when I first looked at the car. I’m supposed to pick up the 59 coronet this weekend and the guy selling it assured me it would be running smoothly, but I’m not holding my breath.
Re: 1959 361ci. swap to 383 [Re: TJP] #2947395
07/26/21 03:08 PM
07/26/21 03:08 PM
moparx Offline
moparx  Offline
unfortunately, i may have to agree with this.
looking through my myriad of FSMs, the 1960 plymouth manual shows an 8 bolt crank flange on the 361.
with that being said, i don't know if if the bolt circle is the same diameter as the later 6 bolt 383. if it is, it may be possible to machine up an adapter to make the crank flange the same length as the 361, then modify the flex plate from an 8 bolt to a 6 bolt by slotting a couple of holes.
however, i would have to see both cranks and be able to precisely measure the flanges and the bolt patterns to be even remotely certain this may be feasible.
beer
Re: 1959 361ci. swap to 383 [Re: rapom] #2947396
07/26/21 03:13 PM
07/26/21 03:13 PM
moparx Offline
moparx  Offline
the newer heads will work, but the compression will be lowered a little by the 383 open chamber heads vs the closed chamber 361's.
at least i think the 361 has closed chamber heads in that year. i have been way wrong many times before though. biggrin
beer
Re: 1959 361ci. swap to 383 [Re: rapom] #2947439
07/26/21 04:49 PM
07/26/21 04:49 PM
My first Mopar car was a 1959 Dodge Coronet with a 326 C.I. poly motor(one year only, Dodge used the 318 poly motors after 1959) and a Powerflyte 2 speed tranny. blush
I remember the other 1959 Dodges with BB in them were either "Royals or Custom Royals, not Coronets work scope
Is this a 2 barrel or 4 barrel motor?
It should have four bolt valve covers with aluminum rocker arm shaft hold down if it is a pre 1964 361 motor scope
I'm not sure when Mopar, all brands, stop using the 361 and 413 motors in the passenger cars confused
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947442
07/26/21 05:00 PM
07/26/21 05:00 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
It’s a custom royal. I’m not sure of the carb. yet. I used Coronet because it was easier to type. Didn’t realize the name could dictate what engine it got. Still have a lot to learn about these cars.
Re: 1959 361ci. swap to 383 [Re: moparx] #2947449
07/26/21 05:20 PM
07/26/21 05:20 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
beer
but what about using the 361 crank into the 383 block as mentioned?
won't the 383 block meet the 727 iron case ?
and yes, 361 got open chambers BUT smaller valves too. Can't tell about piston height difference thought
Re: 1959 361ci. swap to 383 [Re: Cab_Burge] #2947451
07/26/21 05:23 PM
07/26/21 05:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
pretty sure the 413 when the 440 was released and the 361 when the 383B... Maybe ?
or wasn't the 426 wedge a replacement fro the 413, then the 440 the replacement for the 426 ?
something like that LOL
Re: 1959 361ci. swap to 383 [Re: NachoRT74] #2947453
07/26/21 05:28 PM
07/26/21 05:28 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
beer
but what about using the 361 crank into the 383 block ?
They say it's an eight bolt flange on the 361 vs. 6 bolts for the 383. Seems like the 383 might already have a flex plate attached? I know nothing of the balance problems. IIRC, the closed chamber head engines have the piston lower in the bore vs. the later open chambers. So he's getting the 906 heads over whatever closed chamber heads he has now. If I was younger, I'd enjoy the challenge of getting it all figured out and have fun doing it, not these days though...
'69 300 Convertible
'16 300 S Hemi
Page 1 of 3 1 2 3
