Broke an axle.... again.... #2946842
07/25/21 01:24 AM
07/25/21 01:24 AM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
So years at the track I broke a stock axle, no big surprise it was 40 years old or so... Replaced the axles with Strange axles and today I snapped another one, on the street. Was fooling around and did a half hearted burnout, just enough that it hooked hard and bang... I haven't torn it apart yet but I suspect I twisted it off at the spline as before.
So now I'm torn, do I buy axles again or just bite the bullet and finally put a Dana in this thing.
If I was still employed it'd be a no brainer however I'm on disability since cancer surgery, chemo etc...
Needless to say money is an issue. Considering Dr Diff for a new Dana, anyone have an idea, what the dimensions I need to give him are for a 67 B body, stock width, I do have Caltracs and Mono leafs on the car.
My 8 3/4 has a Detroit Locker but I don't remember how many splines it is I also have no idea how I got the broken stub out before, I know I didn't pull the pig...
This stuff was a lot easier before but these days just cutting my grass kicks my butt so I'm trying to come up with a plan I can actually manage on my own...
Just looking for suggestions, I really just want to replace axles but I also need it to hold up to my stupidity...
67 Coronet
400 Block 500" stroker, 10.8 compression
Bulldog heads (yes I'm the guy who bought the only set they sold. Yes I'm know they sold more, at least 1 more set I'm sure... Lol)
Cam is ~630 lift, .263 duration
MP M1 single plane
CRT trans
Dynamic converter ~ 3800 stall
Det Locker 4.30 gears
Thanks!
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Broke an axle.... again.... [Re: Sledge_57] #2946856
07/25/21 06:25 AM
07/25/21 06:25 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
How many years did the replacement last? If you get 10 years out a set of shafts is it worth the swap?
Do they make bigger splines for 8.75 axles?
Angry white pureblood male
Re: Broke an axle.... again.... [Re: ruderunner] #2946893
07/25/21 10:07 AM
07/25/21 10:07 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Those 30 spline axles can only take so much. Usually a 3200 pound car will start twisting axles when you get into the 10 second bracket. We replaced our 8 3/4 with a Dana 60 (35 spline) and never had a failure since, car now runs 10.0's at 133 mph.
Re: Broke an axle.... again.... [Re: GODSCOUNTRY340] #2946901
07/25/21 10:23 AM
07/25/21 10:23 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Pretty sure 35 spline axles are the same weather they are for an 8 3/4 or a dana. So no upgrade there.
I would just replace what you had maybe they offer a better version now (better material). It surprises me a good after market axle would fail with a half hearted burn out on the street.
Re: Broke an axle.... again.... [Re: GODSCOUNTRY340] #2946903
07/25/21 10:30 AM
07/25/21 10:30 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
The 3800 stall is the issue. Lowering the stall would help. If that's not an option the dana would be the way to go. A cheaper option would be to get a 9 1/4 axle.
Re: Broke an axle.... again.... [Re: Moparite] #2946923
07/25/21 11:02 AM
07/25/21 11:02 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
What tires are on it? If you have some sticky ones on it and it's just a street toy what about more of a street tire. Letting the tires spin is a bit easier on diffs and axles. My B'cuda with a 470" stroker, 4 spd and 8.25(3:73) has held up well.....it don't hook worth a damn but the diff/axles live fine. I don't race it so I don't care if it hooks. Does hella nice burnouts though grin drive
Re: Broke an axle.... again.... [Re: Dcuda69] #2946960
07/25/21 12:38 PM
07/25/21 12:38 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just reading the history, this is what I think:
1) axle #1 - old age gets everything
2) axle #2 - stuff happens
I'd put another axle in what you have and motor on, especially with the financial situation you say you are in. Sometimes I think there is a tendency (and I'm not immune to it either) to start replacing major components after a failure when the actual problem was a minor component failure.
Re: Broke an axle.... again.... [Re: 6PakBee] #2946973
07/25/21 01:06 PM
07/25/21 01:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Call Strange, they may warranty it. If they say "No" all you're out is a phone call
Re: Broke an axle.... again.... [Re: Sledge_57] #2946981
07/25/21 01:20 PM
07/25/21 01:20 PM
I bought and used a set of Strange Engr. 35 spline axles and spool in my old pump gas Duster, I also added a steel cap on the driver side for increase strength and proactive to prevent breaking the stock left cap.
I had ladder bars with coil overs and that car went low tens a lot before it twisted up that 8 3/4 housing bad enough to rip the welds off of the ladder bar mounts on the passenger side on the starting line puke
I bought a junkyard Dana 60 out of a pickup and had it cut down and reuse those Strange 35 spline axles with a new dana 60 3 seris 35 spline spool, no more problems after that up work
On your deal if you do decide to swap to the 35 spline parts make sure and buy a steel cap and have it installed on the driver side twocents up
Re: Broke an axle.... again.... [Re: Sledge_57] #2946983
07/25/21 01:28 PM
07/25/21 01:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some here have said that competition axles don't do well on the street.
Re: Broke an axle.... again.... [Re: John_Kunkel] #2947004
07/25/21 02:37 PM
07/25/21 02:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Many years ago I called Strange to order some a-body axles, and the lady said they don't recommend their axles for street use, or anything involving lots of cornering with a spool.
Re: Broke an axle.... again.... [Re: Sledge_57] #2947038
07/25/21 04:30 PM
07/25/21 04:30 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
No manufacturer will warranty a 30 spline axle against breakage.
Your only other alternative is a 35 spline spool and axles.
Re: Broke an axle.... again.... [Re: DoctorDiff] #2947081
07/25/21 07:26 PM
07/25/21 07:26 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Replace the axle, I'd consider going back to a stock one if the car is mainly used on the street. Then back off the cal-tracks a bit, let spin on the street. You will have more fun, and the car will like it better, just watch the tach more closely. If your going back to the strip, tighten up the cal-tracks to hook again.
Re: Broke an axle.... again.... [Re: DoctorDiff] #2947177
07/25/21 11:11 PM
07/25/21 11:11 PM
Dearborn Hts, MI
Dearborn Hts, MI
I know and I'd never ask about a warranty on 12 year old axles anyway...
Will be contacting you soon...
Doug
Re: Broke an axle.... again.... [Re: Sledge_57] #2947323
07/26/21 01:10 PM
07/26/21 01:10 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm about 30 north of the city, so not that far. If you need another pair of hands putting a 60 in drop me a PM. Could burn a Saturday or Sunday.
Re: Broke an axle.... again.... [Re: MarkZ] #2947326
07/26/21 01:13 PM
07/26/21 01:13 PM
Dearborn Hts, MI
Dearborn Hts, MI
Thank you for the offer!
Doug
Re: Broke an axle.... again.... [Re: Sledge_57] #2947331
07/26/21 01:20 PM
07/26/21 01:20 PM
Dearborn Hts, MI
Dearborn Hts, MI
So I think I'm going to roll the dice on axles again. The Strange shafts I broke were a "Street axle" they sold years ago and I see they have "Alloy induction hardened shafts" that they recommend for street use now.
When I replaced my axles 12 years ago, the new Strange axles were slightly too long and had to cut about 1/2" off the spline.
The housing is all original to the car so I ordered axle lengths to fit a stock housing but if I remember correctly the Locker has a spacer / button in the center between the axle shafts. The original stock axles worked fine with the Locker though,
So is it the "Green Bearings" that caused the issue or did I just get unlucky and get the wrong length shafts the first time?
If "Green Bearings" caused the issue I may go back to tapered bearings.
I'd like to not have to cut the new axles again after I order them...
Doug
Re: Broke an axle.... again.... [Re: Sledge_57] #2947415
07/26/21 04:14 PM
07/26/21 04:14 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
First comment, you got 12 years out of the Strange axles? Wow, what did you expect to get? confused I think that is pretty good. Second comment, as to spacers, I thought that when you retrofitted with the 'Green' bearings you removed all of the centering pins as they are no longer needed AND they may preload the bearings. Finally, as an example, with the AMC 20 differential it is common to have to shorten the available axles, Mr. Chop Saw is our friend here. Cutting something off the end is not unheard of.
Re: Broke an axle.... again.... [Re: 6PakBee] #2947428
07/26/21 04:31 PM
07/26/21 04:31 PM
an8sec70cuda Offline
I'd recommend a set of Moser axles. I've seen a bunch of broken Strange axles. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Broke an axle.... again.... [Re: 6PakBee] #2947475
07/26/21 06:36 PM
07/26/21 06:36 PM
Dearborn Hts, MI
Dearborn Hts, MI
Not sure about that spacer, was never told it wasn't needed...
Doug
