Re: Broke an axle.... again.... [Re: Sledge_57] #2947483
07/26/21 06:58 PM
07/26/21 06:58 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I have 750 passes on my Strange 35 spline axles. Previous car had 1500+ on Strange 35 spline. Current car weighs 3350. 60fts are in the 1.2x range.
Doug
Re: Broke an axle.... again.... [Re: dvw] #2947532
07/26/21 09:02 PM
07/26/21 09:02 PM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
Doug
Mine are 30 spline and the car lives on the street, went to the track twice since I broke the first axle, probably not taking it again.
These axles have ~ 2000 street miles on them. Blew up the 470 about 10 years ago, put a sick 383 in after that and the 500" motor went in a month or two before the cancer diagnosis (2019) So 2019 and last year the car maybe had 50 miles total.
Finally got it running right late this spring, so not much time on it this year either...
I don't see 30 spline axles available on DR Diff site so looking at Dutchman.
Anyone had good or bad experiences with them?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Broke an axle.... again.... [Re: Sledge_57] #2947578
07/26/21 10:18 PM
07/26/21 10:18 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by Sledge_57
Originally Posted by 6PakBee
First comment, you got 12 years out of the Strange axles? Wow, what did you expect to get? confused I think that is pretty good. Second comment, as to spacers, I thought that when you retrofitted with the 'Green' bearings you removed all of the centering pins as they are no longer needed AND they may preload the bearings. Finally, as an example, with the AMC 20 differential it is common to have to shorten the available axles, Mr. Chop Saw is our friend here. Cutting something off the end is not unheard of.
Not sure about that spacer, was never told it wasn't needed...
I tried to find out where I had read that and can't drag it up. So I have to file what I said under hearsay or BS.
Re: Broke an axle.... again.... [Re: 6PakBee] #2947589
07/26/21 10:38 PM
07/26/21 10:38 PM
The centered floating spacers in all the early posi in both 8 3/4 and Dana 60 were used to help set the endplay up on the Timken tapered roller axle bearings scope
You don't need to worry about setting the end play correctly with ball bearings on the axles like the Green bearings are as long as it has some end play your good in my book up,
Been there done that up wrench
Re: Broke an axle.... again.... [Re: Sledge_57] #2947616
07/26/21 11:39 PM
07/26/21 11:39 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I'm also a Dutchman axle dealer. They now offer a 4130 cr-mo steet/strip axle.
Re: Broke an axle.... again.... [Re: Cab_Burge] #2947617
07/26/21 11:40 PM
07/26/21 11:40 PM
Dearborn Hts, MI
Dearborn Hts, MI
Thanks, never really thought about what that was there for but it makes perfect sense.
Now can I get it out without pulling the center section? I'm guessing not...
And if I do have to pull it I think I'm going to re-gear it, 4:30's are fun but I'm thinking 3:55 or 3:73...
Doug
