Koffels Place #2946047
07/22/21 01:24 PM
07/22/21 01:24 PM
USA
hudsonhornet7x Offline OP
USA
I have not heard much about them in a long time. Would this place still be recommended for a Mopar engine build?
Re: Koffels Place [Re: hudsonhornet7x] #2946121
07/22/21 05:37 PM
07/22/21 05:37 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
I dropped a block off about a month ago for machining (Huron).
Never been there,clean well organized shop.
Saw a lot of cool high end stuff.
Mike
Re: Koffels Place [Re: hudsonhornet7x] #2946168
07/22/21 07:59 PM
07/22/21 07:59 PM
NC
440Jim Offline
440Jim  Offline
NC
I never had them build an engine.
Are you going to use B1 Mopar heads? That is what they are known for.
I bought a set of "new" B1 original heads from another racer that went in another direction before he built a complete motor. That racer had them ported and prepped, but never used.
I have talked to Scott Koffel a few times, and he has been helpful.
Re: Koffels Place [Re: 440Jim] #2947223
07/26/21 07:20 AM
07/26/21 07:20 AM
an8sec70cuda Offline
Great guys to deal with and very helpful. up
Not sure who calibrates their dyno though.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Koffels Place [Re: an8sec70cuda] #2947372
07/26/21 01:15 PM
07/26/21 01:15 PM
They should be able to calibrate their dyno, the local Studka brand dyno I use to test on found out by calibrating it after a conflict with the former operator it was making more power before calibrating it than after, 975HP at 7300 RPM on a 572 C.I. bracket motor with max ported 440-1 heads and a 440=3x intake and a single 1150 CFM Dominator or what ever size that carbs was.
We calibrated it and it lost right at 100 HP with all the same temps and air density shock
Dram ( RIP up) was correct on that dyno being happy before recalibrating it shruggy
My motor still made more power than his did with the same parts whistling devil
Re: Koffels Place [Re: Cab_Burge] #2948120
07/28/21 10:49 AM
07/28/21 10:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I was just there yesterday. Scott can taka care of whatever you need and always has a number of engines in the works.
