Best Hyd Cam Manf. Whos your choice? #2945494
07/21/21 09:25 AM
07/21/21 09:25 AM
west palm beach, florida
modelmakerinc Offline OP
Thought about doing a poll but way too many choices.
Wondering what manufactures are favored by the engine builders here? RE: hydraulic flat tappet cams for quality, availability, variety customer service support. Im not asking anything about application or use or prfile. just brand preference. Thanks Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Best Hyd Cam Manf. Whos your choice? [Re: modelmakerinc] #2945531
07/21/21 11:16 AM
07/21/21 11:16 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I didn't go with a hydraulic but I switched over from Comp to Howards this time around and I'm very happy with the SFT I have. Good power and smooth break-in procedure and it's been about 1100 street miles and it's nice and quiet with with tight lash. I wouldn't hesitate to install another Howards cam twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best Hyd Cam Manf. Whos your choice? [Re: modelmakerinc] #2945546
07/21/21 11:48 AM
07/21/21 11:48 AM
PA
Harry's Taxi 2 Offline
PA
Crower
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Best Hyd Cam Manf. Whos your choice? [Re: modelmakerinc] #2945613
07/21/21 01:34 PM
07/21/21 01:34 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'm by no means an "engine builder" but do help my dad assemble the engines we run. We've used Mopar Performance, Comp and Lunati cams. We ran hydraulic for years and in the past 6-7 years have starting to switch to mechanical flat tappets. I only remember 1 issue with a cam and lifter going bad and that was an older cam that prob had 30 years of abuse on it.
Re: Best Hyd Cam Manf. Whos your choice? [Re: DusterKid] #2945618
07/21/21 01:43 PM
07/21/21 01:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I called Bullet , gave them my info and they ground me a cam that does exactly what I wanted.
a 408 that makes 492 lb ft and 492 h.p. with a flat torque curve that is over 400 lb.ft from 2500 on up.
I could have eeked another 8 h.p. with carb tuning , and been able to say 500 , but I was sharing the day on the pump with a buddy and didn't want to leave him short of time.
It was also on a hot , humid day , so it is right about the conditions where it will be driven in.
The cam is just part of the combination , but this is the second they have done for me ..........the other was a solid roller for a 48 degree deal , and I am very happy with both.
Re: Best Hyd Cam Manf. Whos your choice? [Re: modelmakerinc] #2945706
07/21/21 04:57 PM
07/21/21 04:57 PM
PA
PA
Here's an additional suggestion, verify that you actually got the lobes that your cam card says it is.......no matter what brand you end up going with.
Re: Best Hyd Cam Manf. Whos your choice? [Re: Harry's Taxi 2] #2945917
07/22/21 07:50 AM
07/22/21 07:50 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Got a Racer Brown in mine. twocents
