Anyone running an Aftermarket K on a 64 B body
#2942959
07/14/21 09:38 AM
07/14/21 09:38 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Just tossing around some ideas to drop some weight. Anyone out here running an aftermarket K member in a 64 B body? If so whos is it? Is the car driven any on the street? Just thinking out loud and pondering future possibilities.
Re: Anyone running an Aftermarket K on a 64 B body
[Re: John Burdine]
#2942971
07/14/21 10:11 AM
07/14/21 10:11 AM
Al_Alguire
Las Vegas
IIRC there use the T bars and old steering box?
[Re: John Burdine]
#2943056
07/14/21 01:13 PM
07/14/21 01:13 PM
Al_Alguire
Las Vegas
Guess i need to look harder the QA1 stuff I saw was T bar stuff
[Re: John Burdine]
#2943133
07/14/21 04:18 PM
07/14/21 04:18 PM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
here is the website www.gerstsuspensions.com They sold out to to QA1 - They make the best front end out there right now - a buddy of mine put one on a dart - real quality piece and easy to install from what he told me The QA1 set-up for torsion bars weighs as much as a K-frame - the only advantage I see is oil pan clearance - the rest of the components such as a-arms and such are nice pieces
[Re: DoubleD]
#2943142
07/14/21 04:44 PM
07/14/21 04:44 PM
Al_Alguire
Las Vegas
Gotcha...I'm old and slow..
Andy my son and I could covert it to a Mustang II deal easy enough but not what I am looking to do. Trying to keep it as stock as possible, already have tube chassis cars.
[Re: Sammy]
#2943227
07/14/21 08:23 PM
07/14/21 08:23 PM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have a Gerst front in my 67 , nice piece .. Carl is a good guy
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: J_BODY]
#2943301
07/15/21 05:20 AM
07/15/21 05:20 AM
Posts: 2,915 A shed in England
Tig
A shed in England
I have a QA1 K member on the Challenger. Frees up some room for a long pan, uses stock type suspension components. Though just for info, you have to cut most of the drivers side engine mount away if you run external oiling.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2943361
07/15/21 10:40 AM
07/15/21 10:40 AM
Al_Alguire
Las Vegas
Currently the car has a motor plate and would stay that way. Engine in it makes a few HP's and if it gets replaced with the Hemi I have lying around it also makes pretty good power so engine will stay on a plate. Car weighs 3460 right no and just looking to try and drop some tonnage where I can. I get the Gerst/QA1 thing, just didnt see they were seperate deals under one banner now and will look into those. I have had an alterkation and dont like the front track being pushed out, at least like an A bodies is. I dont need this for any additional clearance for sure. Have a custom pan on it now and a set of custom headers that all work fine. Really just looking at dropping some weight. Maybe I should just start trimming and cutting away at the stock piece.
[Re: Al_Alguire]
#2943368
07/15/21 10:56 AM
07/15/21 10:56 AM
Tig
A shed in England
Currently the car has a motor plate and would stay that way. Engine in it makes a few HP's and if it gets replaced with the Hemi I have lying around it also makes pretty good power so engine will stay on a plate. Car weighs 3460 right no and just looking to try and drop some tonnage where I can. I get the Gerst/QA1 thing, just didnt see they were seperate deals under one banner now and will look into those. I have had an alterkation and dont like the front track being pushed out, at least like an A bodies is. I dont need this for any additional clearance for sure. Have a custom pan on it now and a set of custom headers that all work fine. Really just looking at dropping some weight. Maybe I should just start trimming and cutting away at the stock piece. IIRC there was 2lbs difference in favor of the QA1, before I cut it.
[Re: Tig]
#2943371
07/15/21 11:02 AM
07/15/21 11:02 AM
Al_Alguire
Las Vegas
IIRC there was 2lbs difference in favor of the QA1, before I cut it. Well pretty sure we could loose more than 2lbs modifying whats there. Why I was looking at something that went to a rack and no t bars, but maybe I am overcomplication things as what i have works fairly well. Car has run 8's and other than the cage and bars looks like a Sunday cruiser.
[Re: Al_Alguire]
#2943587
07/15/21 02:28 PM
07/15/21 02:28 PM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
... just looking to try and drop some tonnage where I can. ... I have had an alterkation and dont like the front track being pushed out, at least like an A bodies is. I dont need this for any additional clearance for sure. Have a custom pan on it now and a set of custom headers that all work fine.... Maybe I should just start trimming and cutting away at the stock piece. "Have a custom pan on it now and a set of custom headers that all work fine." That would be a big decision choice point if you started from scratch which would more justify the expense to be in-line with the benefits. If we consider how much lighter Doug's '64 is (3330 with 2 optima batteries) using a 125lb heavier block, there SHOULD be a fair amount of low hanging fruit to save weight? I'd bet trimming what you have AND converting to front coil-overs and leaving the factory steering would be only 25 lbs heavier than a full-tube/rack K kit. My fiberglass decklid saved over 50lbs there should be 50-60 lbs saving on a 'glass hood. ALL side windows and rear window/back glass can be done in lexan and still be functional and LOOK 'real'. (60? lbs) Your new cage/frame work might save 25lbs...for starters
