Do I need to measure before ordering a drive shaft #2942559
07/13/21 09:05 AM
07/13/21 09:05 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Just got our Strange from Dr. Diff.
Car is a 71 RR, originally a BB 833 converted to a 727.
Diff has a 1350 D60 yoke.
Should I wait until everything's together and measure yoke to trans spline
or is this a no-brainer for a shaft supplier?
Thanks, Joe
Re: Do I need to measure before ordering a drive shaft [Re: jlatessa] #2942562
07/13/21 09:29 AM
07/13/21 09:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you’d said “71 Duster” I could have hooked you up! Get everything installed and measure…..
Re: Do I need to measure before ordering a drive shaft [Re: J_BODY] #2942569
07/13/21 10:13 AM
07/13/21 10:13 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I doubt a driveshaft company would take an order without you measuring. Most companies have a form for you to fill out. That way when it is wrong it is your fault.
Re: Do I need to measure before ordering a drive shaft [Re: NITROUSN] #2942571
07/13/21 10:21 AM
07/13/21 10:21 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Answers are what I expected, thanks for the guidance, Joe
Re: Do I need to measure before ordering a drive shaft [Re: jlatessa] #2942588
07/13/21 11:01 AM
07/13/21 11:01 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The standard length and diameter are known since that was an available option for your car when new.
JB Rhinehart, Realist
A-Body's RULE!
Re: Do I need to measure before ordering a drive shaft [Re: Rhinodart] #2942617
07/13/21 12:27 PM
07/13/21 12:27 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Are the Strange housing dimensions an exact match as the OE Dana's?
Any other considerations?
Thanks, Joe
Re: Do I need to measure before ordering a drive shaft [Re: jlatessa] #2942638
07/13/21 01:08 PM
07/13/21 01:08 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
What is the proper measurement from the trans to the yoke?
Thanks, Joe
Strange 60 seems pretty close to O.E. I ordered my drive shaft through Mancini racing. I started with what the factory service manual stated, minus half the difference in diameter between 7290 U-joint caps and a 1350 shruggy Hindsight 20/20, I would've been fine with what the service manual said drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
