Re: removing parts car ignition lock cylinder
[Re: Sniper]
#2942000
07/11/21 11:25 AM
07/11/21 11:25 AM
Posts: 5,841 ohio
ruderunner
ohio
Locking column no?
Pull the steering wheel and push the lock pin down or remove the lockplate
Angry white pureblood male
[Re: ruderunner]
#2942039
07/11/21 02:08 PM
07/11/21 02:08 PM
Posts: 19,456 north of coder
moparx
i agree on pulling the wheel and removing the lock plate, plus hop under, or under the hood, and unhook the transmission linkage to get neutral. by the time a guy screws around with a slide hammer, hammer and chisel [wacking ones hand and learning kewl new words in the process ], etc, you can do the above in the same amount of time, saving aggravation and self inflicted pain. which of course, any bystanders will find extremely entertaining.
[Re: dusterdood]
#2942045
07/11/21 02:27 PM
07/11/21 02:27 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Use a small drill bit and drill the pins out of the cylinder. No need to remove anything.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: moparx]
#2942060
07/11/21 03:08 PM
07/11/21 03:08 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
i agree on pulling the wheel and removing the lock plate, plus hop under, or under the hood, and unhook the transmission linkage to get neutral. by the time a guy screws around with a slide hammer, hammer and chisel [wacking ones hand and learning kewl new words in the process ], etc, you can do the above in the same amount of time, saving aggravation and self inflicted pain. which of course, any bystanders will find extremely entertaining. X 3 Doesn't take long to remove the wheel. If you're strong enough, you don't need a puller. Leave the nut on for a thread or 2 so you don't smack yourself in the face with the wheel and then pull on the wheel. My Dad taught me that trick years ago. ...by the time a guy screws around with a slide hammer, hammer and chisel [wacking ones hand and learning kewl new words in the process... Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: GTSDart340]
#2942084
07/11/21 04:26 PM
07/11/21 04:26 PM
Posts: 4,733 Florida
BDW
Use a small drill bit and drill the pins out of the cylinder. No need to remove anything. This Cordless drill, no crawling under car, done in 2 minutes
[Re: BDW]
#2942163
07/11/21 09:41 PM
07/11/21 09:41 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Use a small drill bit and drill the pins out of the cylinder. No need to remove anything. This Cordless drill, no crawling under car, done in 2 minutes X3 You aren't going to be able to save the cylinder anyway. Drill the cylinder lengthwise a little below the bottom of the key slot and you'll take all the pins out. Cylinder will turn with no problem.
[Re: dusterdood]
#2942266
07/12/21 09:12 AM
07/12/21 09:12 AM
6PakBee
North Dakota
You don't need anything special. Just be aware that drilling though the cylinder lock pins isn't smooth drilling. Don't rush things, there is always a chance of hanging the bit up and breaking it. That would not be good.
[Re: 6PakBee]
#2942305
07/12/21 11:56 AM
07/12/21 11:56 AM
moparx
You don't need anything special. Just be aware that drilling though the cylinder lock pins isn't smooth drilling. Don't rush things, there is always a chance of hanging the bit up and breaking it. That would not be good. having worked with small drill bits my entire career, it takes a careful feel with the speed [rpm] and feed rate to be successful in drilling deep holes [more than 1/8-3/16"] in solid material, let alone an "interrupted" cut, like you will encounter drilling out the lock pins. add in using a hand drill that can "catch" the pins and break, because the rpm and feed rate [pushing on the hand drill] usually varies, try this knowing the bit breakage possibility up front. it can be done [i have done it, so how hard can it be ? ], but most guys get in a hurry. just my experience, your mileage will vary.............
[Re: moparx]
#2942313
07/12/21 12:13 PM
07/12/21 12:13 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
big flat blade screwdriver with hex on shaft, put in key slot turn with wrench
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2942538
07/13/21 06:37 AM
07/13/21 06:37 AM
Posts: 615 Rochester, NY
dusterdood
Rochester, NY
big flat blade screwdriver with hex on shaft, put in key slot turn with wrench Interesting, how does this work? Hammer the flat blade into the key slot, and just force it past the tumblers? Thanks for all the replies guys. Think I'll bring a 5/8" hardened bit and drill it out
[Re: dusterdood]
#2942555
07/13/21 08:46 AM
07/13/21 08:46 AM
6PakBee
North Dakota
IMHO, even if you are removing something you don't need at the moment, that is no excuse to go medieval on it unless that is your only choice. Shoot, you could cut the steering column in two pieces with a torch and accomplish the same thing.
