removing parts car ignition lock cylinder #2941967
07/11/21 08:39 AM
07/11/21 08:39 AM
Rochester, NY
dusterdood Offline OP
Rochester, NY
I found a rusty '73 Duster parts car. Owner lost the key. Doors are unlocked, so I'm wondering about the easiest way to pull the ign cylinder from the column without actually removing much of anything. Just to unlock the wheel and get it up onto my trailer. The old movies showed car thieves inserting a slide hammer tool and simply pulling the cylinder in one strike. I don't want the column, so I don't care about damage to the cylinder. Can I drill out the tumblers quickly, or pry/pull out the cylinder?
Thanks in advance.
Re: removing parts car ignition lock cylinder [Re: dusterdood] #2941983
07/11/21 10:10 AM
07/11/21 10:10 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just disconnect the linkage at the trans or bottom of the column, put it in N and roll. No need to damage anything you might be able to use or sell.
Re: removing parts car ignition lock cylinder [Re: Sniper] #2942000
07/11/21 11:25 AM
07/11/21 11:25 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Locking column no?
Pull the steering wheel and push the lock pin down or remove the lockplate
Angry white pureblood male
Re: removing parts car ignition lock cylinder [Re: ruderunner] #2942039
07/11/21 02:08 PM
07/11/21 02:08 PM
moparx Offline
moparx  Offline
i agree on pulling the wheel and removing the lock plate, plus hop under, or under the hood, and unhook the transmission linkage to get neutral.
by the time a guy screws around with a slide hammer, hammer and chisel [wacking ones hand and learning kewl new words in the process biggrin], etc, you can do the above in the same amount of time, saving aggravation and self inflicted pain. which of course, any bystanders will find extremely entertaining. boogie laugh2
beer
Re: removing parts car ignition lock cylinder [Re: dusterdood] #2942045
07/11/21 02:27 PM
07/11/21 02:27 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Use a small drill bit and drill the pins out of the cylinder. No need to remove anything.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: removing parts car ignition lock cylinder [Re: moparx] #2942060
07/11/21 03:08 PM
07/11/21 03:08 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
beer
iagree X 3 Doesn't take long to remove the wheel. If you're strong enough, you don't need a puller. Leave the nut on for a thread or 2 so you don't smack yourself in the face with the wheel and then pull on the wheel. My Dad taught me that trick years ago. up
Quote
...by the time a guy screws around with a slide hammer, hammer and chisel [wacking ones hand and learning kewl new words in the process...
laugh2 laugh2 laugh2
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: removing parts car ignition lock cylinder [Re: GTSDart340] #2942084
07/11/21 04:26 PM
07/11/21 04:26 PM
BDW Offline
BDW  Offline
This
Cordless drill, no crawling under car, done in 2 minutes
Re: removing parts car ignition lock cylinder [Re: BDW] #2942163
07/11/21 09:41 PM
07/11/21 09:41 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This
X3 You aren't going to be able to save the cylinder anyway. Drill the cylinder lengthwise a little below the bottom of the key slot and you'll take all the pins out. Cylinder will turn with no problem.
Re: removing parts car ignition lock cylinder [Re: 6PakBee] #2942247
07/12/21 07:49 AM
07/12/21 07:49 AM
Rochester, NY
Rochester, NY
I was hoping it would be this easy. I'll just grab my battery powered drill when I go see it in case it comes home with me. Do I need a hardened bit? Or is it soft metal in there.
Re: removing parts car ignition lock cylinder [Re: dusterdood] #2942266
07/12/21 09:12 AM
07/12/21 09:12 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You don't need anything special. Just be aware that drilling though the cylinder lock pins isn't smooth drilling. Don't rush things, there is always a chance of hanging the bit up and breaking it. That would not be good.
Re: removing parts car ignition lock cylinder [Re: 6PakBee] #2942305
07/12/21 11:56 AM
07/12/21 11:56 AM
moparx Offline
moparx  Offline
having worked with small drill bits my entire career, it takes a careful feel with the speed [rpm] and feed rate to be successful in drilling deep holes [more than 1/8-3/16"] in solid material, let alone an "interrupted" cut, like you will encounter drilling out the lock pins. add in using a hand drill that can "catch" the pins and break, because the rpm and feed rate [pushing on the hand drill] usually varies, try this knowing the bit breakage possibility up front.
it can be done [i have done it, so how hard can it be ? ], but most guys get in a hurry.
just my experience, your mileage will vary.............
beer
Re: removing parts car ignition lock cylinder [Re: moparx] #2942313
07/12/21 12:13 PM
07/12/21 12:13 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
big flat blade screwdriver with hex on shaft, put in key slot turn with wrench
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: removing parts car ignition lock cylinder [Re: 440lebaron] #2942340
07/12/21 02:24 PM
07/12/21 02:24 PM
BDW Offline
BDW  Offline
If you're going to drill, why use small bit?
Go big or don't bother.
Re: removing parts car ignition lock cylinder [Re: 440lebaron] #2942538
07/13/21 06:37 AM
07/13/21 06:37 AM
Rochester, NY
Rochester, NY
Interesting, how does this work? Hammer the flat blade into the key slot, and just force it past the tumblers?
Thanks for all the replies guys.
Think I'll bring a 5/8" hardened bit and drill it out
Re: removing parts car ignition lock cylinder [Re: dusterdood] #2942555
07/13/21 08:46 AM
07/13/21 08:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
IMHO, even if you are removing something you don't need at the moment, that is no excuse to go medieval on it unless that is your only choice. Shoot, you could cut the steering column in two pieces with a torch and accomplish the same thing.
