46re stand alone shift mod ???? #2942245
07/12/21 07:38 AM
07/12/21 07:38 AM
Beaumont, Texas
cwkerr007 Offline OP
Beaumont, Texas
I read through some old threads but couldn't find what i needed if someone can steer me towards a solution i'll dance at your wedding and i only have 1 leg so it would be entertaining lol don't worry nobody but my balet teacher is mad lol so i have a 1988 dakota that i put a 2000 5.9 46re out of a 3500 van in and i carbed and hei and put 3:73 gear with 295/50/15 (don't rem the tire height ) and the only opt i can find for the trans is to go full man vb with the transgo shift reprog anyone have a link to a solution ????
Re: 46re stand alone shift mod ???? [Re: cwkerr007] #2942276
07/12/21 09:29 AM
07/12/21 09:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
2000 has JTEC pcm controlled lockup and OD….. not sure on that unit how you’ll work around that.
Re: 46re stand alone shift mod ???? [Re: J_BODY] #2942283
07/12/21 10:20 AM
07/12/21 10:20 AM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
Re: 46re stand alone shift mod ???? [Re: roadrunninMark] #2942289
07/12/21 10:38 AM
07/12/21 10:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by roadrunninMark
It's for the 46RH versions, not the 46RE versions.
Re: 46re stand alone shift mod ???? [Re: Sniper] #2942303
07/12/21 11:47 AM
07/12/21 11:47 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Look up PATC they have the kits to do what you want
Re: 46re stand alone shift mod ???? [Re: cudaman1969] #2942310
07/12/21 12:10 PM
07/12/21 12:10 PM
GA
GA
Yes, does show RH versions. Maybe OP can contact them and see if will work on the RE.
Re: 46re stand alone shift mod ???? [Re: cwkerr007] #2942382
07/12/21 04:53 PM
07/12/21 04:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 46re stand alone shift mod ???? [Re: John_Kunkel] #2942505
07/13/21 12:39 AM
07/13/21 12:39 AM
Beaumont, Texas
Beaumont, Texas
sorry it takes me so long to answer guys thank you for the help it's ironic that i called the place cuda was sending me and they don't sell one but they sent me to e trans i could have saved all that time on the phone procrastinating and just checked my email and got the goods from ya'll lol thanks jon they have two of them actually they just updated there old ones one is full manual and still electric with a rocker switch for 400+ and a full auto with a gear ind gauge and other nic naks for 700+i'm usually a cheapy person but in this case i can't see myself shifting that monster with that little manual electric switch some one (probably one of my kids) would be riding in it and get it on video then photo shop me shifting with my pinky and i would have to cash in that walmart gift card and fill there car with silly string lol anyway thanks again ya'll for the help ya'll were right on the money and i'll send ya'll an update on how it works as soon as i figure out how i'm going to incorperate that quicksilver floor shifter into the plan cause i paid way to much for that thing so i told ya'll i was cheap !! I wouldn't be able to sleap if i took that thing out lol thanx again charlie
Re: 46re stand alone shift mod ???? [Re: cudaman1969] #2943808
07/16/21 06:18 AM
07/16/21 06:18 AM
Beaumont, Texas
Beaumont, Texas
if you run across someone else this is the link all the other ones i found have been for rh http://www.e-transcontrol.com/dodge-transmission/
Re: 46re stand alone shift mod ???? [Re: cwkerr007] #2944210
07/17/21 10:29 AM
07/17/21 10:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You can put in a good 46RH and the kit that PATC sells and still be under the $695 price tag for the controller!
Re: 46re stand alone shift mod ???? [Re: cwkerr007] #2944260
07/17/21 12:16 PM
07/17/21 12:16 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Can you swap a 46th valve body in to your 45re, or is there more to it than that?
Re: 46re stand alone shift mod ???? [Re: mgoblue9798] #2944332
07/17/21 04:25 PM
07/17/21 04:25 PM
A727Tflite Offline
A727Tflite  Offline
All RH transmissions have a mechanical/hydraulic governor.
All RE use electronics to develop governor pressure.
If you have a RE, installing a RH valve body will get you no upshift. Unless, of course you install a manual valve body.
Re: 46re stand alone shift mod ???? [Re: A727Tflite] #2944484
07/18/21 09:05 AM
07/18/21 09:05 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Install a complete 46RH transmission not just a valve body!
