Re: Wedge block into a Hemi block ?
[Re: hemienvy]
#2940696
07/07/21 01:48 AM
07/07/21 01:48 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
I'm sure this has been tried over the years, but please enlighten me. The 4 inboard head bolt / head stud positions, can you make a wedge block accept Hemi heads ? No You need the cast in holes for the inner head studs to seat against also
I know the main caps won't be the same. Isn't the only really tricky part the 4 head bolt mounts? NO, the push rods hit the block and would need grinding the valley a lot, some of the early Mopar Pro Stock racers tried doing that swap on 383 blocks, it didn't work back then either Is it possible, just not feasible or practical ? Not feasible, my two cents
Even the motor mounts you can get around. I would buy the better newer thicker Hemi blocks form World, FHO or Bill Mitchell
[Re: dart games]
#2940740
07/07/21 08:07 AM
07/07/21 08:07 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Look at all the filler in the water jackets on that old pro stock block. The front water jackets on the deck don't line up, so you'll have to do some work there. I think you break into water when you grind the pushrod clearance also. Probably not a huge deal if it's gonna be a dry block/alcohol combo. A little more work if you need a cooling system.
I remember a magazine article years ago about a guy that had a sand rail/dragster that had a modified 400 low deck block to accept hemi heads. Ran it NA, but alcohol injected IIRC. They'd welded tubes in the valley for the inner head studs.
[Re: an8sec70cuda]
#2940744
07/07/21 08:39 AM
07/07/21 08:39 AM
Posts: 674 st.louis,mo.
dart games
st.louis,mo.
another pic i had,anything can be done if you have enough time and money.looks like they use wrist pins for the tube,this block is a 383.but you would have to build a intake for it
[Re: hemienvy]
#2940860
07/07/21 02:42 PM
07/07/21 02:42 PM
Posts: 8,255 fredericksburg,va
cudaman1969
fredericksburg,va
Then the head oil return holes at the block corners. Could use a stud-nut like the Stage V conversion head did, they used a different rocker arm instead of cutting for the pushrod.
[Re: cudaman1969]
#2940908
07/07/21 05:44 PM
07/07/21 05:44 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just build a wedge engine. If you are afraid of going that fast put a throttle stop or a two barrel carb on it.
[Re: hemienvy]
#2941098
07/08/21 09:49 AM
07/08/21 09:49 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
My question would be a pretty simple one WHY? There are plentiful sources for a new Hemi block these days so why bother. Back in the day it was done out of necessity.
[Re: Al_Alguire]
#2941105
07/08/21 09:57 AM
07/08/21 09:57 AM
cudaman1969
fredericksburg,va
My question would be a pretty simple one WHY? There are plentiful sources for a new Hemi block these days so why bother. Back in the day it was done out of necessity. Bigger question, why do we do anything? I’m sure every endeavor in history was asked that same question
[Re: cudaman1969]
#2941108
07/08/21 10:01 AM
07/08/21 10:01 AM
Al_Alguire
Las Vegas
My question would be a pretty simple one WHY? There are plentiful sources for a new Hemi block these days so why bother. Back in the day it was done out of necessity. Bigger question, why do we do anything? For enjoyment, pleasure. But why reinvent the wheel when there is a readily available source for blocks? This was done in the dark ages because there was no option. If it is being done to "save" money then I would have to ask why one would be doing this at all
[Re: Al_Alguire]
#2941120
07/08/21 10:20 AM
07/08/21 10:20 AM
an8sec70cuda
My question would be a pretty simple one WHY? There are plentiful sources for a new Hemi block these days so why bother. Back in the day it was done out of necessity. While I agree completely...if I had the time, skill, and the tools to do the work required, I'd probably try it just for the heck of it.
[Re: hemienvy]
#2941150
07/08/21 11:17 AM
07/08/21 11:17 AM
an8sec70cuda
The oil drainbacks at the bottom corners of the hemi heads obviously won't line up w/ the wedge block. You could plug them from the bottom of the head and then drill and tap it from the side for an AN fitting and run hoses down to the pan like on a B1 head.
[Re: an8sec70cuda]
#2941156
07/08/21 11:29 AM
07/08/21 11:29 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Never realized how much work it entailed to put Hemi heads on a wedge block. I remember back in the early-mid 80s someone wrote one of the car mags asking about putting wedge heads on a Hemi block. The answer was it would not be a problem and that if they weren't running NASCAR, they must be running 'shine. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
