Wedge block into a Hemi block ? #2940691
07/06/21 11:39 PM
07/06/21 11:39 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I'm sure this has been tried over the years, but please enlighten me.
The 4 inboard head bolt / head stud positions, can you make a wedge block accept Hemi heads ?
I know the main caps won't be the same.
Isn't the only really tricky part the 4 head bolt mounts?
Is it possible, just not feasible or practical ?
Even the motor mounts you can get around.
Re: Wedge block into a Hemi block ? [Re: hemienvy] #2940696
07/07/21 01:48 AM
07/07/21 01:48 AM
The 4 inboard head bolt / head stud positions, can you make a wedge block accept Hemi heads ? No tsk You need the cast in holes for the inner head studs to seat against also scope
Isn't the only really tricky part the 4 head bolt mounts? NO, the push rods hit the block and would need grinding the valley a lot, some of the early Mopar Pro Stock racers tried doing that swap on 383 blocks, it didn't work back then either down
Is it possible, just not feasible or practical ? Not feasible, my two cents
I would buy the better newer thicker Hemi blocks form World, FHO or Bill Mitchell up scope
Re: Wedge block into a Hemi block ? [Re: Cab_Burge] #2940726
07/07/21 06:04 AM
07/07/21 06:04 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
they did that in the 70s in pro stock
E1C02F77-2F26-4F42-8FC0-413A9939148F.jpeg.jpg28626088-C329-4204-BD40-0C330BEA1402.jpeg.jpgProMotor.jpg
Re: Wedge block into a Hemi block ? [Re: dart games] #2940740
07/07/21 08:07 AM
07/07/21 08:07 AM
an8sec70cuda Offline
Look at all the filler in the water jackets on that old pro stock block. The front water jackets on the deck don't line up, so you'll have to do some work there. I think you break into water when you grind the pushrod clearance also. Probably not a huge deal if it's gonna be a dry block/alcohol combo. A little more work if you need a cooling system.
I remember a magazine article years ago about a guy that had a sand rail/dragster that had a modified 400 low deck block to accept hemi heads. Ran it NA, but alcohol injected IIRC. They'd welded tubes in the valley for the inner head studs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Wedge block into a Hemi block ? [Re: an8sec70cuda] #2940744
07/07/21 08:39 AM
07/07/21 08:39 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
another pic i had,anything can be done if you have enough time and money.looks like they use wrist pins for the tube,this block is a 383.but you would have to build a intake for it
Re: Wedge block into a Hemi block ? [Re: dart games] #2940748
07/07/21 09:07 AM
07/07/21 09:07 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I forgot about the pushrod clearance.
Re: Wedge block into a Hemi block ? [Re: hemienvy] #2940860
07/07/21 02:42 PM
07/07/21 02:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Then the head oil return holes at the block corners. Could use a stud-nut like the Stage V conversion head did, they used a different rocker arm instead of cutting for the pushrod.
Re: Wedge block into a Hemi block ? [Re: cudaman1969] #2940887
07/07/21 04:11 PM
07/07/21 04:11 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
what about a cam?
Re: Wedge block into a Hemi block ? [Re: Handygun] #2940905
07/07/21 05:28 PM
07/07/21 05:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Handygun
what about a cam?
Well it has to be a Hemi cam.
Re: Wedge block into a Hemi block ? [Re: cudaman1969] #2940908
07/07/21 05:44 PM
07/07/21 05:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just build a wedge engine. If you are afraid of going that fast put a throttle stop or a two barrel carb on it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wedge block into a Hemi block ? [Re: pittsburghracer] #2940917
07/07/21 06:03 PM
07/07/21 06:03 PM
iagree haha
I've made more power per C.I. with a wedge with good heads than with a gen 2 hemi motor with comparable parts confused shruggy whiney
Re: Wedge block into a Hemi block ? [Re: Cab_Burge] #2940949
07/07/21 08:32 PM
07/07/21 08:32 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
agree cab,for the money and power cant go wrong with a wedge
Re: Wedge block into a Hemi block ? [Re: dart games] #2941000
07/07/21 10:53 PM
07/07/21 10:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I think this conversation was about making a wedge block into a Hemi block not which engine is better.
Re: Wedge block into a Hemi block ? [Re: hemienvy] #2941098
07/08/21 09:49 AM
07/08/21 09:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My question would be a pretty simple one WHY? There are plentiful sources for a new Hemi block these days so why bother. Back in the day it was done out of necessity.
Re: Wedge block into a Hemi block ? [Re: Al_Alguire] #2941105
07/08/21 09:57 AM
07/08/21 09:57 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Bigger question, why do we do anything? I’m sure every endeavor in history was asked that same question
Re: Wedge block into a Hemi block ? [Re: cudaman1969] #2941108
07/08/21 10:01 AM
07/08/21 10:01 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
For enjoyment, pleasure. But why reinvent the wheel when there is a readily available source for blocks? This was done in the dark ages because there was no option. If it is being done to "save" money then I would have to ask why one would be doing this at all
Re: Wedge block into a Hemi block ? [Re: Al_Alguire] #2941120
07/08/21 10:20 AM
07/08/21 10:20 AM
While I agree completely...if I had the time, skill, and the tools to do the work required, I'd probably try it just for the heck of it.
CHIP
Re: Wedge block into a Hemi block ? [Re: an8sec70cuda] #2941140
07/08/21 10:56 AM
07/08/21 10:56 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Everyone's comments are good.
My thinking was, A lot of Street-type Hemi engines are making less than 700 horse,
so a 440 block would be strong enough just for tooling around.
Re: Wedge block into a Hemi block ? [Re: hemienvy] #2941150
07/08/21 11:17 AM
07/08/21 11:17 AM
The oil drainbacks at the bottom corners of the hemi heads obviously won't line up w/ the wedge block. You could plug them from the bottom of the head and then drill and tap it from the side for an AN fitting and run hoses down to the pan like on a B1 head.
CHIP
Re: Wedge block into a Hemi block ? [Re: an8sec70cuda] #2941156
07/08/21 11:29 AM
07/08/21 11:29 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Never realized how much work it entailed to put Hemi heads on a wedge block. I remember back in the early-mid 80s someone wrote one of the car mags asking about putting wedge heads on a Hemi block. The answer was it would not be a problem and that if they weren't running NASCAR, they must be running 'shine. laugh2
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
