Single layer steel shim head gasket? #2940671
07/06/21 09:29 PM
07/06/21 09:29 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Anyone ever run just a single layer steel shim head gasket with aluminum heads on iron blocks?
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2940683
07/06/21 10:16 PM
07/06/21 10:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Pretty sure the 028 gasket i ran on my old 360 the last 4 years was a steel shim Mr Gasket single layer.
Eddie heads, stock 360 block. No issues.
https://www.manciniracing.com/mrgathstshhe.html
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2940697
07/07/21 01:52 AM
07/07/21 01:52 AM
Yep, stock .017 thick Fel Pros on several B and RB builds with both 440 Source and Eddy RPM aluminum heads with no issues so far luck
9.44 to 10.5 to 1 compression made to run on Oregon 91 octane non ethanol pump gas.
Re: Single layer steel shim head gasket? [Re: Cab_Burge] #2940723
07/07/21 04:31 AM
07/07/21 04:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I'm running a single steel shim on my street car. I bought a Cometic gasket & just used the outer layer since they have all the right embossing grooves on them.
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2940732
07/07/21 07:22 AM
07/07/21 07:22 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I ran Mopar Performance and than later the Mr. Gasket ones for years. The engines I used them on were never decked so I used them to help up the compression. Never had an issue with them.
Re: Single layer steel shim head gasket? [Re: rebel] #2940814
07/07/21 12:51 PM
07/07/21 12:51 PM
Kalispell Mt.
Kalispell Mt.
I have done exactly this with iron heads and block but am a little scared to try it with aluminum heads butt that is exactly what I am contemplating right now (6.4 BGE with single layer from each head gasket to give a cheap compression and quench boost). I guess since the heads are not really that hard to swap on these I will probably just give it a shot and put regular ones back if I have a problem.
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2940839
07/07/21 01:39 PM
07/07/21 01:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Been running a 440 with Eddy heads on a motor I built for a friend. Going on 4 years with single layer shim. 10.0-1 never a problem.
Doug
Re: Single layer steel shim head gasket? [Re: dvw] #2940843
07/07/21 01:53 PM
07/07/21 01:53 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
What is the advantage of these one-piece shim type gaskets ?
Are they just cheaper ? Do they hold more pressure between an iron block and iron heads ?
Better at withstanding higher temperatures ?
Less sensitive to surface finish ?
Re: Single layer steel shim head gasket? [Re: hemienvy] #2940846
07/07/21 02:03 PM
07/07/21 02:03 PM
Kalispell Mt.
Kalispell Mt.
They seem to last extremely long times, I still pull apart 440 340 318 273s... with the original ones still functioning. They should survive overheating better as they expand and contract at pretty much the exact same rate as the iron block and head. They are cheap. You don't lose any compression if you are low on compression ratio, if you got an engine like a 77 400 or 318 4bbl "cop engine" than your already bad compression ratios turn to Briggs and Stratton compression ratios if you put on thicker composite head gaskets.
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2940906
07/07/21 05:30 PM
07/07/21 05:30 PM
AndyF Offline
AndyF  Offline
It can be done but the failure rate is pretty high. The OEMs tried using steel shim gaskets when aluminum heads first came out and the warranty returns just about killed them. Eventually they developed the MLS gasket which solved the problem.
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2941001
07/07/21 10:54 PM
07/07/21 10:54 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yes, 11:1 here and no issues
Re: Single layer steel shim head gasket? [Re: HotRodDave] #2941057
07/08/21 01:52 AM
07/08/21 01:52 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I've been running the same gaskets for 8 years now with Stage 6 heads on an iron block. I did have the heads off about 3 years back but a spray with copper coat & they went back on, still no issues. I'm running 11;1cr on pumpgas.
Re: Single layer steel shim head gasket? [Re: rebel] #2941531
07/09/21 02:20 PM
07/09/21 02:20 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am using a mr gasket shim with iron block and eddy heads, no issues. I did it to get compression up. The gasket already had some kind of coating -- looked like silver paint (maybe like silver BBQ paint), so I didn't add any additional coating to it. If it were uncoated I would either use BBQ paint or copper spray.
