Single layer steel shim head gasket?
#2940671
07/06/21 09:29 PM
07/06/21 09:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Anyone ever run just a single layer steel shim head gasket with aluminum heads on iron blocks?
Re: Single layer steel shim head gasket?
[Re: HotRodDave]
#2940683
07/06/21 10:16 PM
07/06/21 10:16 PM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
Anyone ever run just a single layer steel shim head gasket with aluminum heads on iron blocks? Pretty sure the 028 gasket i ran on my old 360 the last 4 years was a steel shim Mr Gasket single layer. Eddie heads, stock 360 block. No issues. https://www.manciniracing.com/mrgathstshhe.html
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: HotRodDave]
#2940697
07/07/21 01:52 AM
07/07/21 01:52 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Yep, stock .017 thick Fel Pros on several B and RB builds with both 440 Source and Eddy RPM aluminum heads with no issues so far 9.44 to 10.5 to 1 compression made to run on Oregon 91 octane non ethanol pump gas.
[Re: rebel]
#2940814
07/07/21 12:51 PM
07/07/21 12:51 PM
HotRodDave
Kalispell Mt.
I'm running a single steel shim on my street car. I bought a Cometic gasket & just used the outer layer since they have all the right embossing grooves on them. I have done exactly this with iron heads and block but am a little scared to try it with aluminum heads butt that is exactly what I am contemplating right now (6.4 BGE with single layer from each head gasket to give a cheap compression and quench boost). I guess since the heads are not really that hard to swap on these I will probably just give it a shot and put regular ones back if I have a problem.
[Re: hemienvy]
#2940846
07/07/21 02:03 PM
07/07/21 02:03 PM
HotRodDave
Kalispell Mt.
What is the advantage of these one-piece shim type gaskets ?
Are they just cheaper ? Do they hold more pressure between an iron block and iron heads ?
Better at withstanding higher temperatures ?
Less sensitive to surface finish ? They seem to last extremely long times, I still pull apart 440 340 318 273s... with the original ones still functioning. They should survive overheating better as they expand and contract at pretty much the exact same rate as the iron block and head. They are cheap. You don't lose any compression if you are low on compression ratio, if you got an engine like a 77 400 or 318 4bbl "cop engine" than your already bad compression ratios turn to Briggs and Stratton compression ratios if you put on thicker composite head gaskets.
[Re: HotRodDave]
#2940906
07/07/21 05:30 PM
07/07/21 05:30 PM
Posts: 31,050 Oregon
AndyF
Anyone ever run just a single layer steel shim head gasket with aluminum heads on iron blocks? It can be done but the failure rate is pretty high. The OEMs tried using steel shim gaskets when aluminum heads first came out and the warranty returns just about killed them. Eventually they developed the MLS gasket which solved the problem.
[Re: HotRodDave]
#2941001
07/07/21 10:54 PM
07/07/21 10:54 PM
Posts: 5,163 CT
GTX MATT
CT
Yes, 11:1 here and no issues
[Re: HotRodDave]
#2941057
07/08/21 01:52 AM
07/08/21 01:52 AM
Posts: 4,647 aotearoa
rebel
aotearoa
I'm running a single steel shim on my street car. I bought a Cometic gasket & just used the outer layer since they have all the right embossing grooves on them. I have done exactly this with iron heads and block but am a little scared to try it with aluminum heads butt that is exactly what I am contemplating right now (6.4 BGE with single layer from each head gasket to give a cheap compression and quench boost). I guess since the heads are not really that hard to swap on these I will probably just give it a shot and put regular ones back if I have a problem. I've been running the same gaskets for 8 years now with Stage 6 heads on an iron block. I did have the heads off about 3 years back but a spray with copper coat & they went back on, still no issues. I'm running 11;1cr on pumpgas.
