Page 2 of 3 1 2 3
Re: Zero energy '79 Power Wagon [Re: I_bleed_MOPAR] #2940228
07/05/21 05:55 PM
07/05/21 05:55 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I want to do the complete one; I actually took it to a local auto electric shop that's been in business for 40 years and he said "I did a bunch of those back in the day but I don't do them anymore". He's an older guy and not a conversationalist so I didn't ask why. I guess one day I'll take it on myself. I try to stay with real simple stuff. As Inspector Callahan said, "A man's got to know his limitations" laugh
Facts are stubborn things.
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940246
07/05/21 07:17 PM
07/05/21 07:17 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I hear ya. Electrical problems have never been my strong suit. Back around 1976 my first car - a 70 Cuda 340, developed an electrical problem - an intermittent one. Sometimes the car would just go dead - like your scenario. I took it over to "Livonia Auto Electric" - what more do you need in a name than that? The guy called me a couple hours later & said "car's ready - 35-bucks." When I got there I asked him what went wrong. He showed me a wire under the dash & said he installed a fuseable link, which I saw. I don't know if the wire melted down like yours or why, but he said "they do that a lot - you won't have that problem anymore." Anyway, never had that problem again.
Also many years ago - summer 1968-9, we were on vacation in Michigan's UP - middle of nowhere, & our few year old 65 Ford wagon decided that when you turned on the headlights, the ignition would just cut-out - car went dead. My Dad took it to some small rural auto repair place & the guy fixed the problem. I don't remember the whole story - wish my Dad was still around so he could fill me in on the details. That same trip, one of the wheel bearings went bad too & we had to get that fixed on the road as well. Thinking back, those were problems that should have never happened on a 3-4 year old car. I've never been crazy about Phord products, & my wife's 2013 Edge is NO exception!
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940269
07/05/21 08:29 PM
07/05/21 08:29 PM
Guitar Jones Online laugh2
Poor connections will cause excessive resistance and heat. Wiring and connections that aren't sealed well will eventually corrode and cause poor connections. Cut out any discolored wires and by that I mean the copper strands. Solder fresh wire back together and use heat shrink with sealer to insulate it..
Re: Zero energy '79 Power Wagon [Re: Guitar Jones] #2940487
07/06/21 12:14 PM
07/06/21 12:14 PM
moparx Online content
moparx  Online Content
one of my pet peeves are those cheepy bolt together battery terminal ends guys use on everything when the factory ends get buggered up by guys not using the proper methods to remove them.
then to add to the fun, they bolt on a bunch of extra wires to the 1/4" bolts that hold the strap over the battery cable.
and if that bolt isn't long enough, a longer one is used, and it pokes a hole into the battery case, or becomes a jack bolt that promptly pulls the battery post out of the case. laugh2
beer
Re: Zero energy '79 Power Wagon [Re: moparx] #2940543
07/06/21 03:22 PM
07/06/21 03:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
New wire harness time!
Re: Zero energy '79 Power Wagon [Re: cudaman1969] #2940560
07/06/21 04:35 PM
07/06/21 04:35 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Sunroofcuda, I'm just happy this time it happened in my driveway! I just drove the truck on a 65 mile round trip too.
Moparx I've been watching for NOS positive battery cable because I have one of the crappy ones. Can't stand them either. Look so cheap and perform cheap too.
Thanks Guitar I was wondering if the poor connection and insulation might cause this. I will repair properly! Thanks! If this particular piece was something I could replace I would but this wire comes out of the bulkhead.
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940563
07/06/21 04:37 PM
07/06/21 04:37 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
On a different note, I'm disappointed how quickly my Borgeson Steering Shaft got rusty. I know it's surface stuff but it's not like I leave hood open and leave it out in rain. I'm going to clean it up and paint. I also need to clean inner fenders. Always so much to do.
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940575
07/06/21 05:17 PM
07/06/21 05:17 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
can you cut the broken part out, and use a solder butt connector like such, but you prob need 10g.
https://www.summitracing.com/parts/pco-4000kt
your alt is bypassed now so that the current doesn't run through your ammeter? it prob got burned up from charging a really low battery off the alt...
Re: Zero energy '79 Power Wagon [Re: krautrock] #2940592
07/06/21 06:08 PM
07/06/21 06:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Never seen one of those connecters. Interesting. Yes alternator has been bypassed for quite awhile. I connected both wires from amp gauge with brass bolt and wrapped in electrical tape. It still looks good after a year or more; no melting. Thanks all.
Re: Zero energy '79 Power Wagon [Re: krautrock] #2940593
07/06/21 06:11 PM
07/06/21 06:11 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
The alternator isn't bypassed, just the ammeter. That is the current path from the alternator- comes in through one bulkhead connector, flows across the ammeter, and goes back to the battery through another bulkhead connector. Common problem on Mopar cars and trucks (at least Mopars- I don't know if other manufacturers do it the same way). The MAD Electrical link I gave him details the way to do a complete (and proper wink ) bypass on the ammeter.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Zero energy '79 Power Wagon [Re: I_bleed_MOPAR] #2940601
07/06/21 06:30 PM
07/06/21 06:30 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Right just amp gauge bypassed. I swear I'll get to that correct bypass one day, with help from my brother.
Any opinions on my Powermaster 150 amp alternator causing this? I believe factory was 60 amp. Did I blow it with this "upgrade"? Guitar mentioned the poor connection and insulation may have caused the melting and that's what I'm hoping. I don't know what that connection was and if it was a factory thing. Almost looks like there was some kind of inline fuse at one time with transparent sleeve? I can't tell because it was in bad shape when I got truck. All I did was wrap it better with electrical tape.
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940632
07/06/21 07:56 PM
07/06/21 07:56 PM
That connector type is a crimp type, not a solder type but I do both on them for high current caring loads up wrench
You will need a # 8 gauge wire crimper to crimp it properly scope up
Re: Zero energy '79 Power Wagon [Re: Cab_Burge] #2940642
07/06/21 08:11 PM
07/06/21 08:11 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you!!
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940649
07/06/21 08:26 PM
07/06/21 08:26 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
if that wire isn't in the direct path from batt to alt., then i don't see how the 150amp alt would've done that. i'd guess that likely it has been like that and is just now giving you problems. especially if you were in there trying to get your speed cable hooked up and were pushing wires around. i think sometime in the past, the wire got kinked, some of the strands broke and then it burned a bit.
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940781
07/07/21 11:36 AM
07/07/21 11:36 AM
Buford, GA
Buford, GA
That wasn't a dig at you by any means (or anyone else). I did the bolt and nut trick on my sons Charger for several years until I found out about the MAD write-up.
Very possible the alternator aggravated the situation with the increased amps but by no means was it your fault. You could actually cut the wire at the alternator (tape the harness side very well), splice in and run a piece of 10 gauge wire from the alternator to the starter relay (using a 14 ga. fusible link as seen in the MAD write-up). This would take the main load off the bulkhead and the 1979 wiring. wink You'll still have the original wire from the relay feeding the dash circuit. Hence my comment about taping the harness end of the wire at the alternator as it will be "hot" with 12v from the dash circuit.
Wish you were closer. I'd give you a hand with it. up
Tim
'71 Charger 383/727
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940799
07/07/21 12:06 PM
07/07/21 12:06 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
while I was there anyway doing the amp gauge bypass.
on this bypass you did. did you run a new wire from your alt output to the B+ lug on your starter relay?
if not, then yes your 150amp alt could've caused that wire to burn up. most likely if the battery got low and you drove the truck around and let it charge the batt up. it usually burns up the connectors at the bulkhead. so the kink/broken strands in the wire might've been the most resistance in that circuit and why it burned up there...
Re: Zero energy '79 Power Wagon [Re: krautrock] #2940810
07/07/21 12:40 PM
07/07/21 12:40 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I did not do that. Thanks I'll do that. Hopefully I have an engine swap soon and a mini starter same time and will do that. Also I have bigger better battery now and have not been letting it run down. Thank you for this info. The bigger alternator is an example of fixing what wasn't broken. I like overbuilt things but I probably should've stuck with maybe 100 amps max. Larry
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940836
07/07/21 01:36 PM
07/07/21 01:36 PM
RWG75
RWG75
Was AFK for a bit and know ya know tin grille wiring. When it goes dark dark sometimes all ya have is headlights because not through the amp gauge or bypass that turns everything else off. volt meter at battery, work up starter relay, bulk head, gauge, fuse panel buses, fuses, loads. PO questionable wiring is standard issue on top of factory questionable wiring. When in doubt, disco loads you can't id.
Re: Zero energy '79 Power Wagon [Re: ] #2940848
07/07/21 02:15 PM
07/07/21 02:15 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Definitely never had headlights or any other power and jiggling the melted junction in red wire formerly to amp gauge brought everything back so definitely have issue there. Going to clean up that connection real well and hopefully holds me over until engine swap and I'll do some more with starter wiring when I'll add mini starter (as much as I love the sound of the old school Chrysler cranking). Thanks. Larry
Re: Zero energy '79 Power Wagon [Re: larrymopar360] #2940867
07/07/21 03:00 PM
07/07/21 03:00 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
all you need is a little 10g wire and a 12g fusible link, a few inches. solder and heatshrink and three connector lugs (alt, relay and the original alt wire which can also go to the b+ lug on the relay).
with that alt you have on there i would make that top priority. it would suck to burn the bulkhead up and have to replace that stuff.
Page 2 of 3 1 2 3
