14 ply trailer tires?
#2936728
06/25/21 03:43 PM
06/25/21 03:43 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Hi, has anyone replaced their 10 ply race trailer tires with 14 ply? They don't seem to be that much more costly. Maybe they would be more durable? My trailer has a pair of 6,000 lb axles, and with my heaviest car and all my stuff in it, it's probably about 10,500 pound s. Other than the extra cost, is there any drawback to using 14 ply tires? Thanks, Joel.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 14 ply trailer tires?
[Re: Hemi_Joel]
#2936730
06/25/21 03:52 PM
06/25/21 03:52 PM
Posts: 10,029 MN
JERICOGTX
MN
You’ll be able to skid the tires 50 more feet with them!
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2936734
06/25/21 04:11 PM
06/25/21 04:11 PM
Hemi_Joel
Minnesota
And you'd let me do it without saying a word until one popped!
[Re: J_BODY]
#2936801
06/25/21 08:55 PM
06/25/21 08:55 PM
Hemi_Joel
Minnesota
I had the Greenball Towmaster load range E on my old trailer and they held up well.
[Re: Hemi_Joel]
#2936829
06/25/21 10:57 PM
06/25/21 10:57 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Are they 14 ply, or 14 ply "rated"? I had some Michelin XPS ribs rated 10 ply, but they were only 5 ply, 4 steel tread bands, one steel sidewall band.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2936842
06/25/21 11:51 PM
06/25/21 11:51 PM
Hemi_Joel
Minnesota
Rated. I probably should have specified that. I don't know if you can buy the actual ply count tires anymore.
[Re: Hemi_Joel]
#2936858
06/26/21 07:01 AM
06/26/21 07:01 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
i got ride of the 15 in rims and went 16. then you can get higher load tires never had trailer tire problems after that
JAKES AUTOMOTIVE
[Re: JAKE68]
#2936881
06/26/21 09:40 AM
06/26/21 09:40 AM
Posts: 2,114 Byron, NY
W.I.N. Racing
Byron, NY
I too made the switch from 15" to 16" tires. Tire life has improved greatly cost is similar and I believe it even pulls a little easier.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2936894
06/26/21 10:06 AM
06/26/21 10:06 AM
Posts: 1,101 Massillon, Ohio
cudatom
Massillon, Ohio
Just curious if you had any clearance issues after the swap. The 16" tires are approximately 2" larger in circumference than my 15's I need tires and rims so if clearance isn't an issue now would be the time to make the change.
Ok
[Re: Blucuda413]
#2936904
06/26/21 10:44 AM
06/26/21 10:44 AM
Hemi_Joel
Minnesota
My previous trailer came with 15-in Goodyear marathons. I went through about 20 tires before I finally switched to 16-in red ball tow masters. When I ordered my current trailer back in 2015, I specified 6,000 lb axles and 16-in rims with load range e-tires
I see that the load range f 12 ply rating and the load range g 14 ply rating are very readily available for not too much money more than the load range e 10 ply rating. That is why I'm wondering if there's any reason not to upgrade?
[Re: J_BODY]
#2937210
06/27/21 09:51 AM
06/27/21 09:51 AM
Posts: 34,918 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
We bought a new Aluminum deck over 22 foot trailer for local deliveries April 2020 .. we do use it a lot , 400 miles each day easily, it has two 6000 lb axles , we wore the original tires out quickly , by August one was blown out and two were worn out ..I replaced them with Carlisle 14 ply and what a difference .not one problem since and drivers claim the trailer rides better ..we have put about 50,000 miles on them , they do need to be replaced now but , I sent that trailer to my Minnesota location , they will use it much less than we do ..and I bought two new trailers , got them in 6 weeks these I ordered with 14 ply tires
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2938268
06/30/21 08:47 AM
06/30/21 08:47 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I did just that this spring. One of the local racers own a trailer service and sales business and told us about a new tire and many of us have switched to it and been very happy with them. It looks like a very well built tire and I believe they are made here in the US and look to be constructed way better than any of the previous tires I've ran. I'm running the Hercules H-901 ST 235/85/16, they cost $175 each locally Hercules H-901 ST Tire
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#2938308
06/30/21 11:39 AM
06/30/21 11:39 AM
Hemi_Joel
Minnesota
Well, I just pulled the trigger on 6 of the Hercules H-901 ST 235/85/16 14 ply. Thanks for all the info and the recommendation!
[Re: Hemi_Joel]
#2938731
07/01/21 01:41 PM
07/01/21 01:41 PM
Hemi_Joel
Minnesota
Ordered the Herc's off of Ebay yesterday, they showed up today! I'm impressed with the service and with the tires. They are stout! And regroovable. With 6 tires, I'll have 4 on the ground and 2 spares. I think I'll try to find 2 matching rims so I can have the spares in the rotation. They should last a long time. Now I need to find time to mount them.
