Stiff clutch pedal #2935905
06/23/21 07:31 AM
06/23/21 07:31 AM
North Carolina USA
smuggler Offline OP
smuggler  Offline OP
North Carolina USA
Hey folks,
I have a problem with a very stiff clutch pedal. It's a 68 GTS 340 car with standard 833. The car did not have a stiff pedal before I restored it but afterward, it did. I've replaced the bellhousing with a factory correct housing and used dial idicator. Good there. Replaced clutch pressure plate and disc with brand new RAM 3 finger-style. I'm running the factory pedal box (rebuilt with all new bearings) and over-center spring. Still stiff pedal. The z-bar (Torque shaft) and the bellhousing Z bar mount are factory correct I believe (they look like what Brewers shows). Also the clutch pedal rod is factory correct I believe. When I look at the Z-bar though, it looks like the end-closed the bellhousing is not centered. Any ideas?
Re: Stiff clutch pedal [Re: smuggler] #2935906
06/23/21 07:36 AM
06/23/21 07:36 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
ask RAM what the plate pressure is. probably far more than you need.
Re: Stiff clutch pedal [Re: lewtot184] #2935910
06/23/21 07:47 AM
06/23/21 07:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agreee.I used to run a 3200 poundcCleod plate in my 65 Clutch was a bear to push.Now center force and its easy.Rocky
Chrysler Firepower
Re: Stiff clutch pedal [Re: smuggler] #2935911
06/23/21 08:05 AM
06/23/21 08:05 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I've always run stiff, 3 finger clutches. My latest street car, I decided I wanted something a little easier for cruising in traffic. Getting older. I reached out to Centerforce and the tech recommended the CFII (not dual friction). It's so much easier on the leg, zero chatter, smooth release and never hints of slip. I'm only running about 400hp smallblock but I like to grab some gears. Zero complaints and would buy another tomorrow.
Re: Stiff clutch pedal [Re: therocks] #2935913
06/23/21 08:07 AM
06/23/21 08:07 AM
North Carolina USA
smuggler Offline OP
smuggler  Offline OP
North Carolina USA
It's a street clutch. I think 2800 pressure up to 450 HP.
Re: Stiff clutch pedal [Re: smuggler] #2935917
06/23/21 08:36 AM
06/23/21 08:36 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
It's most likely the clutch. If you lay under while someone presses the clutch down and don't see anything wonky or noises, it's probably not a mechanical issue.
Re: Stiff clutch pedal [Re: 80fbody] #2935973
06/23/21 11:25 AM
06/23/21 11:25 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
it's not about horsepower; it's about torque. small blocks are not torque engines. i'd rather have less plate pressure and more friction area on a street car. 440's and street hemis used a 2700-2800lb borg&beck BUT they had a heavier over center spring than the 383's with a 2300lb clutch; and even with the heavier over center spring they were a pain in the a$$ in traffic. this reminds me of way back in the day when a friend had '63 409 with a 3000lb borg&beck with no over center spring; miserable to drive.
Re: Stiff clutch pedal [Re: lewtot184] #2936022
06/23/21 01:41 PM
06/23/21 01:41 PM
North Carolina USA
smuggler Offline OP
smuggler  Offline OP
North Carolina USA
Thanks for all the replies. I'll investigate further.
Re: Stiff clutch pedal [Re: smuggler] #2936450
06/24/21 03:31 PM
06/24/21 03:31 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
You may have the wrong pivot in the bellhousing, or wrong ballstud mount attached to the bellhousing . Go to Brewers site on the internet and look at the component photos. If you don't see the problem , give them a call . They have the knowledge, and all the right components.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Stiff clutch pedal [Re: doctor_mopar] #2936518
06/24/21 07:33 PM
06/24/21 07:33 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Can the Z bar be swapped end for end? I've seen that happen on other vehicles. It throws off the linkage ratio.
Angry white pureblood male
Re: Stiff clutch pedal [Re: ruderunner] #2936529
06/24/21 08:07 PM
06/24/21 08:07 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
shruggy Dunno, I'd guess not if all the factory stuff is in place, BUTTTTT ? Great suggestion.
And to the OP do be aware that the frame side mount will give it up without reinforcement. Myself, I like the Centerforce clutches. probably installed 100 of them in various vehicles, only 1 manufacturing problem. twocents beer
Re: Stiff clutch pedal [Re: TJP] #2936629
06/25/21 09:26 AM
06/25/21 09:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
TJP agree CF clutchs are great Love the one in my 65 Been beat on for years and still works great.Oh yeah make sure the buching etc on the z bar are greased.Rocky
y
Chrysler Firepower
Re: Stiff clutch pedal [Re: ruderunner] #2936683
06/25/21 12:38 PM
06/25/21 12:38 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I feel as though if it could be done, I would have done it frown and caused problems. But I've only worked on Big Block cars. I've had a couple "heavy" pressure plates 3,000+ pounds, even with the overcentre spring it just might be "how it is" shruggy drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Stiff clutch pedal [Re: metallicareload] #2938583
07/01/21 12:39 AM
07/01/21 12:39 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Fix it with a center force. Done.
I want my fair share
