Re: Stiff clutch pedal
[Re: lewtot184]
#2935910
06/23/21 07:47 AM
06/23/21 07:47 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I agreee.I used to run a 3200 poundcCleod plate in my 65 Clutch was a bear to push.Now center force and its easy.Rocky
Chrysler Firepower
[Re: smuggler]
#2936450
06/24/21 03:31 PM
06/24/21 03:31 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
You may have the wrong pivot in the bellhousing, or wrong ballstud mount attached to the bellhousing . Go to Brewers site on the internet and look at the component photos. If you don't see the problem , give them a call . They have the knowledge, and all the right components.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#2936518
06/24/21 07:33 PM
06/24/21 07:33 PM
Posts: 5,936 ohio
ruderunner
ohio
Can the Z bar be swapped end for end? I've seen that happen on other vehicles. It throws off the linkage ratio.
Angry white pureblood male
[Re: TJP]
#2936629
06/25/21 09:26 AM
06/25/21 09:26 AM
therocks
Niles , Ohio
TJP agree CF clutchs are great Love the one in my 65 Been beat on for years and still works great.Oh yeah make sure the buching etc on the z bar are greased.Rocky y
Chrysler Firepower
[Re: ruderunner]
#2936683
06/25/21 12:38 PM
06/25/21 12:38 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Can the Z bar be swapped end for end? I've seen that happen on other vehicles. It throws off the linkage ratio. I feel as though if it could be done, I would have done it and caused problems. But I've only worked on Big Block cars. I've had a couple "heavy" pressure plates 3,000+ pounds, even with the overcentre spring it just might be "how it is"
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
