Re: Green yellow or red stuff brakes
[Re: 68_661charger]
#2935685
06/22/21 03:42 PM
06/22/21 03:42 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
I have a 68 Charger disc upgraded mild street strip car was thinking of changing pads out to EBC pads. I'm not a fan of semi metallic and ceramics aren't available. Only other option is organic which has worked well on another vehicle. What color do you suggest? If this is the company out of Las Vegas then I would highly advise against buying ANYTHING from them! I bought "red stuff" brake pads from them several years ago (once again - if we are talking about the same type of pads) & they disintegrated down to the backing plates in about 4,000 miles - I could not believe it. Worst junk I've ever run for brakes. I contacted them & got nowhere. FYI........
[Re: 68_661charger]
#2936585
06/25/21 12:08 AM
06/25/21 12:08 AM
Posts: 355 Sparks, Nevada
MoparMike23
Sparks, Nevada
I run EBC Yellows on my Bee. They are super aggressive and quite amazing on a road course track. I’m very happy with EBC but would recommend something milder from them. Be certain to follow their instructions on breaking them in. Makes a world of difference.
Mike
1969 Superbee 440-6 1977 D-150 Adventurer 2000 Jeep TJ 2018 Challenger Scat Pack Shaker 2019 Ram 2500 CTD
[Re: 68_661charger]
#2936634
06/25/21 09:45 AM
06/25/21 09:45 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
The yellows and greens can be used with an oem rotor but aren't the greens for light cars? I ran the Greens on my 2013 F150 and it's about 5500 pounds. Never any inkling of fade when in the mountains or towing. I put 60K miles on that set of pads and rotors and they were still in great shape when I traded it in. I'm usually pretty hard on brakes, but these put up with it very well. I'll be using them on my Cuda if they have a pad for that application.
[Re: gzig5]
#2936647
06/25/21 10:30 AM
06/25/21 10:30 AM
Posts: 949 Indiana
68_661charger
Indiana
Ok thanks good to know on the green ones. I wonder if the green ones are less dusty. I do have steel wheels.
[Re: A990]
#2937288
06/27/21 01:10 PM
06/27/21 01:10 PM
Posts: 19,355 north of coder
moparx
what i don't like about that video, is a couple of things. first, all studs should have nuts on them, and should be torqued to the proper specs. second, there is no mention of cleaning off rust and dirt from the mating surfaces of both the hub and rotor, plus the hub register of the rotor. and third, make sure the friction face you are indicating of the rotor is as clean as possible, and if it has any ridges or hot spots, get it turned first or replaced. just my opinion, your mileage will vary.
