68 69 thumb wheel headlight switch #2935137
06/20/21 09:44 PM
06/20/21 09:44 PM
IL us
I
ink Online content OP
ink  Online Content OP
I
IL us
my dash lights in my 69 Bee don't work . fuses all good . i had this problem in my 70 charger 30 year ago and cant quiet remember if i replaced the headlight switch or the thumb wheel but one or the other was the fix ??? any advice ??? everything else works . also can anyone point me in the right direction on who sells the best switches ??? thank you !!!
Re: 68 69 thumb wheel headlight switch [Re: ink] #2935158
06/20/21 11:31 PM
06/20/21 11:31 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Dash lights are on a separate fuse, but it would be the dimmer if the fuse is good. There has been a guy rebuilding those, but to my knowledge they are not available new.
Re: 68 69 thumb wheel headlight switch [Re: Jim_Lusk] #2935198
06/21/21 08:05 AM
06/21/21 08:05 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I rebuilt ours long ago, it wasn't too difficult.
Took it apart, had to use different fasteners to re-assemble.
cleaned all contacts, re-bedded resistance coil into ceramic with an appliance
touch-up paint and kept light pressure on the coil until repair was solid.
There is a link somewhere either here or one of the Charger forums.
Good luck, let us know how it goes, or with any questions.
Joe
PS If the resistance coil is FUBAR, you'll need to get another switch somewhere
Re: 68 69 thumb wheel headlight switch [Re: jlatessa] #2935378
06/21/21 06:26 PM
06/21/21 06:26 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
If you don't mind the lights being fixed for full brightness then you can just use a 3/4" piece of wire to jumper out across two of the terminals - You no longer have the dimness adjustment anymore but my eyes were OK with the fix... Should be the middle terminal and one of the adjoining ones - I think the one with the black and green/yellow wire (this was on my 68 Road Runner) You can always reverse the mod later if/when you replace the switch.. Insert the switch to hold the jumper wire in place.
Re: 68 69 thumb wheel headlight switch [Re: 68jim] #2935453
06/21/21 11:36 PM
06/21/21 11:36 PM
IL us
I
I
IL us
thanks !!!! I will try this !! seems it would tell me its the switch if lights come on ?? and i see the thumb wheel switches for sale on eBay . I suppose no-one has tried one ??
