Re: SB magnum stroker
[Re: moparz]
#2934756
06/19/21 04:29 AM
06/19/21 04:29 AM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
Pretty sure a Magnum is a bolt-in as long as you get the correct flywheel/flex plate. The blocks have the bosses on them for LA mounts.
[Re: moparz]
#2934779
06/19/21 09:35 AM
06/19/21 09:35 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Depends on whether you use a long block or short block. Magnum heads have a different intake bolt arrangement and a different pattern at the ends for accessories. If it's a stroker it should be internally balanced so any neutral balance flex plate/flywheel and harmonic balancer should work.
[Re: Guitar Jones]
#2934808
06/19/21 11:28 AM
06/19/21 11:28 AM
Posts: 15,915 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
One additional thing I came across but this was on my '89 Diplomat AHB and that was a minor modification on my accessories bracket on the right side head. One of the bosses at front of Magnum head wouldn't allow the LA alternator bracket fit quite right and had to be modified just slightly and welded but wasn't a problem for mechanic who installed it.
I was going from 318 to 360 so I had internal to external balance to consider too, along with different engine mount on right side (IIRC right side) or use of spacers.
Facts are stubborn things.
[Re: moparz]
#2934978
06/20/21 09:21 AM
06/20/21 09:21 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Thx all. Internally balanced. A little jigging for Rt side motor mount probably and a modified alternator bracket. Existing headers bolt up to magnum heads from LA? 👍🏻 If you use edelbrock magnum heads use edelbrock magnum header gaskets. The edelbrock gasket fits the port perfect, other brands are too big, I have found no others that fit right and it can cause a problem on the 2 middle ports. Iron heads are no problem. The alternator just needs a longer bolt and spacer and an LA timing cover. Late w-2 heads used the magnum front bolt setup and it works on them.
