going manual A833 or TKO
#2933911
06/16/21 12:03 PM
06/16/21 12:03 PM
Posts: 2,374 west palm beach, florida
modelmakerinc
Want to get opinions and points of view, pros and cons for comparison. Lets say the car is generic street driving and occasional test and tunes or exhibition type race. (Not, all outs or brackets or money)
healthy 440 with 30" tires gears are 3.55 car weighs 3000
Either will be equipped with a hydraulic clutch.
Each kit purchased from dealer with new or rebuilt parts as a kit,
The TKO 5-speed and all parts is about $6000
The 833 4-speed and all parts is about $5000
nostalgia or originality don't matter, looks don't matter, whats the best transmission for drive-ability, longevity, fun factor?
Thanks Henry
Re: going manual A833 or TKO
[Re: poorboy]
#2934392
06/17/21 10:35 PM
06/17/21 10:35 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I'd go TKO for the overdrive an internal rail shift linkage but IF quality shifting interests you are all. T56 Magnum.
No gear ratio formula or price per gear can help you with this decision. If you like shifting fast, this is the BEST manual transmission ever made.
[Re: modelmakerinc]
#2934567
06/18/21 01:24 PM
06/18/21 01:24 PM
Posts: 291 Anchorage, Alaska
metallicareload
Anchorage, Alaska
go with the tkx. no floor mods supposedly, and way better shifting and power handling ability than the tko. you definitely want the overdrive in the modern world. but it depends what you want to do with the car. I plan on getting a TKX hopefully in the next winter or two. Want to get opinions and points of view, pros and cons for comparison. Lets say the car is generic street driving and occasional test and tunes or exhibition type race. (Not, all outs or brackets or money)
Thanks Henry The TKX should be better in every respect except price and loss of "originality." Overdrive will let you use 4.10 or 4.56 gears and still cruise in the fast lane @ a reasonable RPM. As it is now, with 3.54 gears and 28" tires, my engine runs faster than I care for @ cruise while the car cruises slower than I care for
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Grizzly]
#2935193
06/21/21 07:22 AM
06/21/21 07:22 AM
modelmakerinc
the KITs i was referring to in either scenario were complete from bellhousing to driveshaft shifter to clutch reservoir, almost, if not everything needed to swap. Not just a transmission out of a wreck. With the few responses which are appreciated, It just seems there are not many here with the practical experience to offer a true comparison.
[Re: modelmakerinc]
#2935491
06/22/21 01:06 AM
06/22/21 01:06 AM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
the KITs i was referring to in either scenario were complete from bellhousing to driveshaft shifter to clutch reservoir, almost, if not everything needed to swap. Not just a transmission out of a wreck. With the few responses which are appreciated, It just seems there are not many here with the practical experience to offer a true comparison. Oh really? I sense a bit of pout because I suggested an affordable solution? The usual Mo' Farts period of silence (3 days in this case) and then backlash when I out-think you Clowns. Learn how to weld and fabricate. Anything can be done. Geezuz man, I could build a shifter and crossmember in my sleep. You got 3 grand to play with from my suggestion, figure the rest out with a Fab Shop. Nevermind, throw five thousand bucks at something, and then come back crying on here that you've got vibrations in the driveline, or something doesn't fit right. I don't care, it's not like the subject hasn't been beat to death and well documented on here already.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2935497
06/22/21 01:26 AM
06/22/21 01:26 AM
Posts: 10,049 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Are them prices installed?
Not sure where a viper six speed fits into the mix price wise but after a bit of hunting I scored a 13k mile viper trans for under a grand (800), the new viper crate motor already had the oem clutch, but point being I was under 2k.
I just cant see a 833 "kit" being 5k, that far exceeds my gf101 including the clutch.
Id think unless you have to have it on the road this summer id spend the winter hunting and spend 1/2 the money...... but some have it to burn.
Either way good luck.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2935516
06/22/21 06:14 AM
06/22/21 06:14 AM
modelmakerinc
Grizzly,
You have your panties in a wad pal. I was asking for a comparison of the two in the sense of function for cost. not just a different way to buy a gearbox.
(new TKO $2,795 gearbox only, Rebuilt a833 $1750 gearbox only)
I can afford either and I fabricate just about anything plus take cars to show quality and race just as well. look here: www.modelmakerinc.com
I appreciate your input as well as others but you didn't offer any comparison. I don't expect you think that yours is the only solution or opinion on the matter,
but wait your post does sound like you have the only solution even without regard to what my question was.
Mr Potato Head those are quotes from Brewers, American Powertrain, and Modern Driveline
Thank you RTSE4ME for a true comparison of the two transmissions and the application
[Re: modelmakerinc]
#2935882
06/23/21 02:52 AM
06/23/21 02:52 AM
Posts: 6,033 Salem
Grizzly
Salem
Well, you're still talking 2 to $3000 for a bell housing, shifter, transmission mount and driveshaft. That's excessive. I've driven the 6 speed in an SRT 10 Ram and 6 speed in a Challenger SRT. They are better than my 833's. Originality is the only reason I stay with the 833's.
Mo' Farts
[Re: Grizzly]
#2935884
06/23/21 03:24 AM
06/23/21 03:24 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
The TKX is going to give you the great 5th highway gear and the Tremec will shifter more smoothly.
China is the enemy.
[Re: Mr PotatoHead]
#2935912
06/23/21 08:06 AM
06/23/21 08:06 AM
Posts: 2,115 MD
RTSE4ME
MD
Potato has a another option just say no to synchros and get a G-force 4 or 5sp. Fun factor is very high. Dog rings and sliders > synchros
