Compact tractor rim/tire Q
#2933822
06/16/21 06:56 AM
06/16/21 06:56 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
I have a Ford 1320 that has R-1 tires. I want to get a set of R-3 turf tires on rims for mowing that I can swap out when I'm not using the loader. Seems harder and more expensive than I thought to find replacements. The rears use the same size for both R-1 and R-3. I found these: https://www.agwheelexpress.com/stor...-ford-compact-tractor-wheel--ford-white/ Seems pricey but buying rim shells and making my own centers isn't much better. https://www.millertire.com/categories/wheels-by-size/16x12/ Summit actually carries the tires. https://www.summitracing.com/parts/crr-570080?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+C&utm_term=4581252644079733&utm_content=GSAPI+5d3872a1b3fdb https://www.summitracing.com/parts/CRR-574339?rrec=true Having trouble finding the front rims with 4 3/4 bolt circle and 3 inch pilot hole. The R-1 rims have 2 1/2 inch backspacing but are 12x5 and I need at least 14x6. Anybody here deal much in this area of equipment?
Re: Compact tractor rim/tire Q
[Re: redraptor]
#2933856
06/16/21 09:19 AM
06/16/21 09:19 AM
Posts: 12,084 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have a 1320, too. When I bought it, I got it with the turf tires. I have had to replace the front tires twice and I looked at the Carlisles. They appear to be much lighter than the original Firestones which are not exactly heavy duty. It takes some real hard looking, but the original Firestones were still available 4 years ago when I last bought them. If you can find them, they are a much better choice for our tractors than the Carlisles.
I may have to replace my front rims some day because they are severely rusted on the inside. I had to use a lot of bead sealer last tire change to get the bead to seal. I most certainly do not want to resort to tubes. I have tubes in the rear and they are a pain.
Master, again and still
[Re: DaveRS23]
#2934759
06/19/21 06:34 AM
06/19/21 06:34 AM
redraptor
Greenville, PA
I may have to replace my front rims some day because they are severely rusted on the inside. I have tubes in the rear and they are a pain.
Hopefully someone could point us in the right direction for rims. I have calcium in my rears. Works great but a pain also.
[Re: redraptor]
#2934768
06/19/21 08:22 AM
06/19/21 08:22 AM
Posts: 2,332 Addison Twp, Mi.
RobG
Addison Twp, Mi.
Check out:
Dawson tire
Steiner tractor parts
Nebraska Tire
One if these firms usually have any hard to find part for a tractor.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: redraptor]
#2934903
06/19/21 06:11 PM
06/19/21 06:11 PM
Posts: 2,361 PA
70HemiGTX
PA
Hopefully someone could point us in the right direction for rims. I have calcium in my rears. Works great but a pain also. Don't use Calcium. Our tractors' tires have beet juice in them. Rims don't rust. Plus it is environmentally friendly.
[Re: DaveRS23]
#2958206
08/28/21 07:38 AM
08/28/21 07:38 AM
redraptor
Greenville, PA
Well I ended up buying rim shells and tires from R.E. Miller. He told me no one in the states makes these rims for import tractors, which mine is a Yanmar.
