Re: N2O fuel system [Re: rb446] #2933088
06/14/21 09:21 AM
06/14/21 09:21 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Here is a pic of the fuel cell. It uses about 1/2 of the jug on 3 250 shot passes. Easy to see the level without removing the cap.
'63 Dodge 330
11.19 @ 121 mph
Re: N2O fuel system [Re: GY3] #2933091
06/14/21 09:30 AM
06/14/21 09:30 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Originally Posted by GY3
I use a JAZ Jr. Dragster fuel cell located on the core support where the horns normally go. I mounted an electric pump below it. Works perfectly.
That is what I was thinking.
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2933163
06/14/21 12:10 PM
06/14/21 12:10 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
AS already mentioned 2-3 times. A standalone like this is not necessary and you are just adding weight and complicating your set up. Run your main fuel line to a log and then mount regs for motor and nitrous off that. KISS
....BAD A$$ STREET CAR.....
Re: N2O fuel system [Re: n20mstr] #2933176
06/14/21 12:26 PM
06/14/21 12:26 PM
Toronto
mshred Offline
mshred  Offline
Toronto
When I was spraying, I ran a holley black pump with a single line from the main fuel tank to a Magnafuel log, with a regulator for the engine and another for the nitrous. Simple, easy, and much cleaner in my opinion. Was more then enough to supply a .73 jet in my cheater plate for a 408 sb
Re: N2O fuel system [Re: n20mstr] #2933190
06/14/21 01:00 PM
06/14/21 01:00 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
This is good advice!!, i did install a hidden system and bought everything through nitrous outlet. I did a puck inside the intake, put there plastic fuel cell with pump inside the fender. Noids were under the dash and it worked great. Won a lot of races with it.
The reason i did a stand alone fuel cell is i wanted to run pump gas in main tank tank, and compression was already 11.7. So i put race gas in fuel cell to help bump up octane and avoid detonation.
Re: N2O fuel system [Re: cuda499] #2933202
06/14/21 01:25 PM
06/14/21 01:25 PM
sweden
carter Offline
carter  Offline
sweden
The reason i did a stand alone fuel cell is i wanted to run pump gas in main tank tank, and compression was already 11.7. So i put race gas in fuel cell to help bump up octane and avoid detonation. [/quote]
^^ This ^^
Re: N2O fuel system [Re: carter] #2933205
06/14/21 01:36 PM
06/14/21 01:36 PM
N
n20mstr Offline
n20mstr  Offline
N
^^ This ^^ [/quote]
Yes that can work.....however most pumpgas engines will run faster on pump gas. Adding race fuel is just a substitute for the proper amount of timing retard. My sons duster, race gas 11.40's all pump gas 11.15 case closed . Now if your already borderline on your tune up, even on motor your risking running it on pump gas. The motor needs the same octane on motor or nitrous. I know this may spark a debate, but im pretty sure thats how it is. Retarding timing AND adding race fuel to the mix will slow the car down, you really dont need both , just one or the other...
Just for an example, my engine makes the best NA HP at 42* , with the plate on the timing is 9* no added octane, just lots of retard. AND yes thats the same fuel NA and with N20
Re: N2O fuel system [Re: n20mstr] #2933280
06/14/21 05:56 PM
06/14/21 05:56 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
My reasoning was the fuel system was at its limits n/a.
5/16 fuel line, mechanical pump and a stock tank.
'63 Dodge 330
11.19 @ 121 mph
Re: N2O fuel system [Re: n20mstr] #2935050
06/20/21 01:46 PM
06/20/21 01:46 PM
Phoenix
jinxy Offline
jinxy  Offline
Phoenix
n20mstr
Could post a pic of the fuel log and regulators?
Thinking adding n2o to my ride as well.
Re: N2O fuel system [Re: jinxy] #2935208
06/21/21 08:33 AM
06/21/21 08:33 AM
an8sec70cuda Offline
Here's my setup. Stock tank w/ a sump, two -10 lines to the A1000 pump on the frame rail, one -10 up to the fuel log. Two Holley 803 regulators (one for the carb, other for N2O solenoid). The Aeromotive return regulator on the end of the log sets the head pressure on the log and obviously returns fuel to the tank through a -8 line.
Even though my hemi is a pump gas motor, I spray it on race fuel only. I'd rather have the cushion there and make my tuning window wider. Hurting pistons is expensive.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: N2O fuel system [Re: n20mstr] #2935227
06/21/21 09:41 AM
06/21/21 09:41 AM
UK
rb446 Offline
rb446  Offline
UK
^^ This ^^
Just for an example, my engine makes the best NA HP at 42* , with the plate on the timing is 9* no added octane, just lots of retard. AND yes thats the same fuel NA and with N20 [/quote]
And that IS exactly it up Nitrous doesn't care what fuel you use, timing is everything when things get more serious.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
