Had a leaky intake #2932465
06/12/21 12:18 PM
06/12/21 12:18 PM
North Carolina
469runner Offline OP
North Carolina
The intake manifold was not sealing well on this engine and it was sucking oil. It has been fixed, new plugs installed. But, the new plugs after about 150 miles look a little dark and crusty. How long does it take for the combustion chambers to clean themselves out? Engine runs great now and am using the same heat range as when engine was new.
Re: Had a leaky intake [Re: 469runner] #2932472
06/12/21 12:49 PM
06/12/21 12:49 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Was machining of the manifold required or did you just reseal it successfully?
I bought a brand new Edelbrock Victor 440 intake. When I mocked it up using grease on the heads and Permatex on the manifold. I found the manifold is too wide resulting in the bottom of the ports sitting up over a 1/4" above the floor of my Indy EZ intake ports. I had a local shop cut the manifold mating faces down to make the manifold narrower and bring the port alignment into closer proximity to each other.
Prior to having it cut, I used the Hughes Intake Sealing Tech Tip to verify the angle was correct.
http://www.hughesengines.com/TechArticles/intake_manifolds_articles.php
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
Re: Had a leaky intake [Re: jbc426] #2932485
06/12/21 01:31 PM
06/12/21 01:31 PM
North Carolina
North Carolina
I did check angles and found no irregularities. Aluminum heads and aluminum intake using sheetmetal gasket/valley pan didn't do a good job sealing. Used separate valley tray and Superformance paper intake gaskets to fix.
Re: Had a leaky intake [Re: 469runner] #2932590
06/12/21 06:53 PM
06/12/21 06:53 PM
Oregon, U.S.A
E
elmor353 Offline
elmor353  Offline
E
Oregon, U.S.A
I have found that aluminum doesn't like the stamped bath tub gasket without the paper gaskets sandwiching it. Cast iron heads and intakes do fine without the paper but I have never had an aluminum intake seal properly without them.
Re: Had a leaky intake [Re: elmor353] #2932598
06/12/21 07:23 PM
06/12/21 07:23 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Had the same problem with E Street Heads and a Weiand dual plane on my 383/432 Stroker
Block was not cut , just cleaned up resurface - Made it clear to the machine shop
Used these gaskets on the head side of the valley pan , dry silicone bead side to the heads and ports then Edelbrock Gasgacinch to glue the gaskets to the bottom of tin pan itself
http://www.hughesengines.com/Index/...EJsb2NrIChMb3cgRGVjayk=&partid=33979
Intake manifold side of tin valley pan no gaskets
Has worked awesome so far this summer
My latest set of NGK 6 look great with no oil use
Makes you wonder how much of that oil if any works it’s way through the exhaust system ? Was going thru about a quart every 500 miles or so for a few summers
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
