Rod bearing damage??? #2932133
06/10/21 10:39 PM
06/10/21 10:39 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I pulled my motor that has been having issues with no oil pressure at startup for seconds. The main reason i pulled the motor was to fix some oil leaks. I had the pan off and figured id check the bearings just to see.... what do you guys think? I can feel the lines with my fingernail but cannot catch them.
Re: Rod bearing damage??? [Re: 8urvette] #2932134
06/10/21 10:40 PM
06/10/21 10:40 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
another bearing
Re: Rod bearing damage??? [Re: 8urvette] #2932135
06/10/21 10:41 PM
06/10/21 10:41 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
and what is up with the crank radius here?
Re: Rod bearing damage??? [Re: 8urvette] #2932136
06/10/21 10:41 PM
06/10/21 10:41 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
last bearing pic
Re: Rod bearing damage??? [Re: 8urvette] #2932138
06/10/21 10:51 PM
06/10/21 10:51 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Yuck!!!! I don’t like what I see.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Rod bearing damage??? [Re: pittsburghracer] #2932147
06/10/21 11:21 PM
06/10/21 11:21 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It sure looks like the final finish on that crank was a little off.
Re: Rod bearing damage??? [Re: 4406bbl] #2932155
06/10/21 11:38 PM
06/10/21 11:38 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This ^^^^^^^^^
Re: Rod bearing damage??? [Re: 8urvette] #2932172
06/11/21 01:00 AM
06/11/21 01:00 AM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Looks like you had dirt in the oil, Maybe missed cleaning an oil passage or something during the build. or no filter, or ineffective filter on the crankcase.
Re: Rod bearing damage??? [Re: 8urvette] #2932177
06/11/21 03:05 AM
06/11/21 03:05 AM
I would NOT reuse those bearings tsk twocents
Re: Rod bearing damage??? [Re: Cab_Burge] #2932185
06/11/21 06:30 AM
06/11/21 06:30 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve seen damage on bearings just like that from shops that don’t have the proper tools to run through the bores after a bore and hone. I think my shop calls it a broach. It cleans all of the grit that gets stuck in the microscopic groves of the cly wall after a stone hone. I really clean my cly bores with ATF and a clean paper towel till it comes back with no color except red. It looks like grit got in your oil somehow.
Re: Rod bearing damage??? [Re: 8urvette] #2932249
06/11/21 11:34 AM
06/11/21 11:34 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
What crank are you running, and do you have the correct bearings for it? I tore down a small block stroker that someone else built not too long ago. Scat crank had filet journals, but whoever built it put regular width bearings in with no chamfer. Result was one spun rod bearing and some others looking like your pic. It is time to go through your motor for sure.
Re: Rod bearing damage??? [Re: mgoblue9798] #2932253
06/11/21 11:49 AM
06/11/21 11:49 AM
A727Tflite Offline
A727Tflite  Offline
Do all the rods look like this ?
Do the mains look like this ?
How do the piston skirts look ?
How about can bearings and cam journals ?
In other words, what good and what’s bad in the engine.
If this wear is confined to the rods and mains the gallery’s were likely contaminated. Could have been media from block tumbling, honing oil that had metal in it that was not cleaned, etc.
We need more info.
The bearings look to be the narrow bearings, wide bearings would crowd the journal radius.
Re: Rod bearing damage??? [Re: A727Tflite] #2932293
06/11/21 03:11 PM
06/11/21 03:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
dirt/debris
Re: Rod bearing damage??? [Re: 8urvette] #2932299
06/11/21 03:49 PM
06/11/21 03:49 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
To help determine the dabris take the filter apart and use a magnet in the pleats to see just how much/what you get
Re: Rod bearing damage??? [Re: Clanton] #2932342
06/11/21 08:14 PM
06/11/21 08:14 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Agree with others, contamination, probably all at start up
Re: Rod bearing damage??? [Re: wyoming] #2932345
06/11/21 08:27 PM
06/11/21 08:27 PM
PA.
"Little"John
"Little"John
PA.
Lack of oil pressure on startups isn’t helping the issue. I would want that resolved before it goes back together. Check to make sure all pipe plugs are installed, heck pickup to bottom of pan clearance, install a magnet in a safe place, check your crank thrust clearance with your at it, what kind of oil filter?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Rod bearing damage??? [Re: pittsburghracer] #2932453
06/12/21 11:11 AM
06/12/21 11:11 AM
Alberta
440_Offroader Offline
Alberta
Check your connecting rod side clearance as well. Looks like some hot spots on the side of the crank throw.
Re: Rod bearing damage??? [Re: pittsburghracer] #2932467
06/12/21 12:31 PM
06/12/21 12:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
maybe an anti drainback filter like the Wix 51515R will help speed oil psi on startup.
Re: Rod bearing damage??? [Re: 8urvette] #2932581
06/12/21 06:31 PM
06/12/21 06:31 PM
napa ca
P
procharged 484 Offline
P
napa ca
Are the threads in that rod ok , looks funny to me .
Re: Rod bearing damage??? [Re: procharged 484] #2932733
06/13/21 09:40 AM
06/13/21 09:40 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I pulling the crank and taking it to the shop. Talked to the machinist and he says he will polish it out. So Ill be replacing bearings for rods and mains.
