Re: Rod bearing damage???
[Re: 8urvette]
#2932138
06/10/21 10:51 PM
06/10/21 10:51 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yuck!!!! I don’t like what I see.
[Re: 4406bbl]
#2932155
06/10/21 11:38 PM
06/10/21 11:38 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
It sure looks like the final finish on that crank was a little off. This ^^^^^^^^^
[Re: wyoming]
#2932345
06/11/21 08:27 PM
06/11/21 08:27 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lack of oil pressure on startups isn’t helping the issue. I would want that resolved before it goes back together. Check to make sure all pipe plugs are installed, heck pickup to bottom of pan clearance, install a magnet in a safe place, check your crank thrust clearance with your at it, what kind of oil filter?
[Re: pittsburghracer]
#2932467
06/12/21 12:31 PM
06/12/21 12:31 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
maybe an anti drainback filter like the Wix 51515R will help speed oil psi on startup.
