Test drive getting back in the car more. #2930294
06/05/21 02:42 PM
06/05/21 02:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The car stalled shifting into 2nd too soon and on restart I forgot I shut the f pump off.I still get 10+ # at 6# UD on the blower.[video:youtube]https://studio.youtube.com/video/dIxkO7cT5MI/edit[/video]
Re: Test drive getting back in the car more. [Re: Clanton] #2930301
06/05/21 03:23 PM
06/05/21 03:23 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
When you thumped it I bet your neighborhood cringed in fear for there chain link fences.
Great to see you back at it. up
STOP POTATO HATE!
Re: Test drive getting back in the car more. [Re: Mr PotatoHead] #2930304
06/05/21 03:28 PM
06/05/21 03:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Long way from the street to a fence but you never know.[BOOOO,lol] ty it is good to be in it.
I get on the gas at 1:50 sec and 2:50 into the video and I am suprised to see 10+ # of boost where I took 15% drive out from where I raced it with 14# at 10% OD.
Re: Test drive getting back in the car more. [Re: Clanton] #2930398
06/05/21 08:50 PM
06/05/21 08:50 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Thanks Mike, your the man. that was a great video. I enjoyed checking out the houses and street view in Ohio.
Everytime you gassed it, I laughed. The neighbours must love it when you take it out.
Re: Test drive getting back in the car more. [Re: 572B1] #2930407
06/05/21 09:41 PM
06/05/21 09:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have 3 1/2" side exh with 14" bullet mufflers that help it .The last time i drove it out of the drive was about 1 yr ago.
Re: Test drive getting back in the car more. [Re: Clanton] #2930416
06/05/21 10:35 PM
06/05/21 10:35 PM
What size is your blower? How big is the motors C.I.?
I have pump gas blown 440 in the shop now fixing it from lifter tie bar breaking and ruining two lifters and hurting the cam, it has a BDS 6:71(I'm not sure if it is a standard or bigger rotor 6:71 blower) with two D.P. Holley on it, What size they are I do not know because I haven't check them yet.
It is a street only cruiser, not a racer except for him wanting to do burn outs after leaving some of the local car shows in our local parks shruggy
Re: Test drive getting back in the car more. [Re: Cab_Burge] #2930446
06/06/21 08:57 AM
06/06/21 08:57 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have an 18 strip teflon 8-71 TBS I have used for many yrs[15] 446 wedge .630 112 lsa roller 109 ICL.I am working my way to getting back on the track and reduced the OD to calm thing down and put the exh to quiet things down.To check the boost I could try another gage but it is what it is.I will get to a test n tune soon I hope but I have ET street tires that should be good at lower boost that I was setting the blower at.I need to cert my belts,get slicks,cert my cage[10pt] and test driveing the car was setting the stage to get those to be sure I was ready.
Re: Test drive getting back in the car more. [Re: Clanton] #2930447
06/06/21 09:01 AM
06/06/21 09:01 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
I bet your neighbors hate you.lol Mine cringe every time the garage goes up.
America First!
Re: Test drive getting back in the car more. [Re: carnut68] #2930456
06/06/21 09:46 AM
06/06/21 09:46 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Mine encourage me with a thumbs up a lot of times.
Re: Test drive getting back in the car more. [Re: Clanton] #2930472
06/06/21 11:25 AM
06/06/21 11:25 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just an observation but I noticed different metering blocks on your carbs, billet and stock on each carb which unless the angle channels, emulsion pack and ifr's are the same it's gonna be a bit "off" and why did it keep stalling....
Re: Test drive getting back in the car more. [Re: Thumperdart] #2930478
06/06/21 11:34 AM
06/06/21 11:34 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Like I said above "The car stalled shifting into 2nd too soon and on restart I forgot I shut the f pump off.I still get 10+ # at 6# UD on the blower." I also have the idle a little low for a cold engine but when warm it is better.Yes I have 1 billet metering block on 1 carb but let it go for now pls.The long/short of it is I was able to adj the fuel with the 1 plate to get 10.5 afr so I just left it and went on to other things.
Re: Test drive getting back in the car more. [Re: Clanton] #2930495
06/06/21 12:50 PM
06/06/21 12:50 PM
Thanks for sharing that with me, I 'm assuming that this motor, now 505 C.I. when it was 446 C.I. before, will be limited on power with low boost under driven with the 6;71 so hopefully he won't hurt himself or the bigger motor luck
Re: Test drive getting back in the car more. [Re: Clanton] #2930501
06/06/21 12:57 PM
06/06/21 12:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha.....
Re: Test drive getting back in the car more. [Re: Clanton] #2930535
06/06/21 03:07 PM
06/06/21 03:07 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
On another note my th400 is doing fine in my car.
Re: Test drive getting back in the car more. [Re: Clanton] #2930537
06/06/21 03:13 PM
06/06/21 03:13 PM
tboomer Online work
tboomer  Online Work
Good luck Mike! up
Re: Test drive getting back in the car more. [Re: tboomer] #2930543
06/06/21 03:48 PM
06/06/21 03:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted by tboomer
Good luck Mike! up
And you as well!ty.
Re: Test drive getting back in the car more. [Re: Clanton] #2931892
06/10/21 09:32 AM
06/10/21 09:32 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Welcome back.
Re: Test drive getting back in the car more. [Re: HardcoreB] #2932203
06/11/21 08:38 AM
06/11/21 08:38 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you.I am slowly getting things worked out.I started with towing my car to a car show and shifting the trans for the 1st time in the parking lot just casual driving.I have some trust in the car now and feel a lot better about how things will go.I adapted my headers for a street exhaust w/mufflers so I could drive around testing the car and the bullet mufflers really nocked down the noise.I did what I needed to do to make progress I know it it not pretty.I also made a blower cover so if I go to the track and it rains while towing it will not go in the carbs.
Re: Test drive getting back in the car more. [Re: Clanton] #2932213
06/11/21 09:29 AM
06/11/21 09:29 AM
tboomer Online work
tboomer  Online Work
Mike...I like it! I wish I could drive my 64 on the street... wave
Re: Test drive getting back in the car more. [Re: tboomer] #2932219
06/11/21 10:00 AM
06/11/21 10:00 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I use the term on the street very loosely.I will se how things go this and next yr.The v springs and cam will need changed.
