Re: The rubber hose trick on the distributor
[Re: mxbeep]
#29302
08/27/06 10:29 AM
08/27/06 10:29 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Can this clamp trick be applied to street engines that will show a few thousand miles/years before removal of distributor.
Or is it just a race engine application
thanks
Yep.....you can and really should do it to them all, tollerance stacks can vary so much that some may never notice, while some will walk all over the place. I`ve been doing this in various ways since back in the early 80`s....Just not the rubber hose tho..i`m not too keen on that for something that will not see teardowns occaisionally.
My ![](/ubbthreads/images/graemlins/Twocents.gif) Rick
[Re: mark_gates]
#29304
08/27/06 10:40 AM
08/27/06 10:40 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I did the hose trick and i also tapped the end of the dist tang over to take any play out of the slot, i suppose the clamp would give you peace of mind, great tip though Bigcube. ![](/ubbthreads/images/graemlins/thumbs.gif)
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Black_Sheep]
#29305
08/27/06 10:46 AM
08/27/06 10:46 AM
Posts: 1,624 qc
mxbeep
qc
You can also get the 1/2" clamp at Graingers for $2.64 part # 1L660
Where is Graingers, do they have a online store? i tried ordering from Enco they charge $40.00 shipping on a $2.00 item.
I am in Canada not in australia
[Re: mxbeep]
#29306
08/27/06 11:59 AM
08/27/06 11:59 AM
Prosport not to high jack your post but do small blocks have the same problem, my timing seems to bounce a little ? can this trick be done on the small blocks ? i have play in my shaft up and down, so wouldnt that cause the timing to jump all over being the drive gear could move up and down on the cam gear. i have a rollmaster timing chain and a tensonior on the 416 so it cant be jumping from there. thanks Bondobob
[Re: goldmember]
#29307
08/27/06 12:09 PM
08/27/06 12:09 PM
BradH
...Have you checked out the kit offered by Dvorak?...
Oh, you mean the one that I had Dan install on my distributor just prior to my second dyno session w/ Dwayne P, only to have it cause the entire distributor to wobble when the engine was running... and then started slipping off the shaft... after about 5 minutes of run time? ![](/ubbthreads/images/graemlins/eeek.gif)
It's still sitting on my parts shelf in a zip-loc baggie... and Mr. Dvorak never bothered to reply to my e-mail asking about the issues we encountered w/ it, either. ![](/ubbthreads/images/graemlins/eyes.gif)
Since I don't have a Grainger's account (they deal w/ businesses only, right?) I'll be happy to reimburse anyone who is placing an order for one of those collars shown above if they'd order a second one for me, too. ![](/ubbthreads/images/graemlins/bow.gif)
#29308
08/27/06 01:01 PM
08/27/06 01:01 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Yes it will do the same thing.
Somewhere I have one of the collars that Ed Hamburger used to sell for Mopar distubutors back in the 70's
[Re: mxbeep]
#29309
08/27/06 01:07 PM
08/27/06 01:07 PM
bcrproducts
super gas
super gas
Beepraz I am Canadian as well and in Canada Graingers is called Acklands Grainger. Try them---Greg
[Re: SB412DUSTER]
#29310
08/27/06 02:08 PM
08/27/06 02:08 PM
thanks SB412DUSTER ![](/ubbthreads/images/graemlins/thumbs.gif) i will install them on my small block dist. Bondobob
[Re: bcrproducts]
#29311
08/27/06 03:37 PM
08/27/06 03:37 PM
Posts: 1,624 qc
mxbeep
qc
We have one in town , i will look them up
thanks
[Re: mxbeep]
#29312
08/27/06 07:31 PM
08/27/06 07:31 PM
Posts: 52 Tennessee
DAHEMIKOTA
Tennessee
www.grainger.com I could give you a phone number but there are 350 locations. Akron, Ohio is :330-733-6311 The address is 420 Kennedy Rd 44305-6311. Dan
#29315
08/28/06 03:48 PM
08/28/06 03:48 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
To install it, put the clamp on the dist shaft, way down by the bottom. Tighten the clamp enuff that it won't fall off, but will still slide on the shaft. Install the dist and tighten it down. The installation will position the clamp for zero endplay on the dist shaft and intermediate shaft. Then remove the dist, tighten the clamp on the shaft so it won't slide, re-install the dist, and you are good to go.
That's exactly how I did it! Great HEMI minds think alike. ![](/ubbthreads/images/graemlins/grin.gif)
ps: I used a drop of Loctite on the screws.
Dave, your hemi eyes must of missed that "trick" componet listed in the Hamburger 340/360 Catalog circa 1979, eh?
Leigh, don't be a HATER. I never said the trick was my idea, did I? If you want to give Ed Hamburger credit for it, go right ahead. Happy now? You must be a lot older than me, because I was in my junior year of high school in '79. In the future, I suggest you NOT skank up threads with your garbage posts. Be helpful, not hateful.
am i missing something here ???
[Re: JohnRR]
#29318
08/28/06 04:03 PM
08/28/06 04:03 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I tried getting one from my local graingers and they wouldn't sell to me either. ![](/ubbthreads/images/graemlins/rant.gif) So I ordered one from MSC. mscdirect.com, PN-87856779 for $1.36
The only Carbs I care about are under the hood!
