Page 2 of 4 1 2 3 4
Re: The rubber hose trick on the distributor [Re: ProSport] #29301
08/27/06 09:53 AM
08/27/06 09:53 AM
qc
mxbeep Offline
mxbeep  Offline
qc
Can this clamp trick be applied to street engines that will show a few thousand miles/years before removal of distributor.
Or is it just a race engine application
thanks
Re: The rubber hose trick on the distributor [Re: mxbeep] #29302
08/27/06 10:29 AM
08/27/06 10:29 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
thanks
Yep.....you can and really should do it to them all, tollerance stacks can vary so much that some may never notice, while some will walk all over the place.
I`ve been doing this in various ways since back in the early 80`s....Just not the rubber hose tho..i`m not too keen on that for something that will not see teardowns occaisionally.
My
Rick
Re: The rubber hose trick on the distributor [Re: mxbeep] #29303
08/27/06 10:33 AM
08/27/06 10:33 AM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
I've been watching this hose trick since it appeared last spring. I didn't like the idea either, but I will go with the Grainger collar. My pump gear has enough wear on it now that the timing wanders a couple of degrees at certain rpm's. Thanx all for the update.!
Re: The rubber hose trick on the distributor [Re: mark_gates] #29304
08/27/06 10:40 AM
08/27/06 10:40 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I did the hose trick and i also tapped the end of the dist tang over to take any play out of the slot, i suppose the clamp would give you peace of mind, great tip though Bigcube.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: The rubber hose trick on the distributor [Re: Black_Sheep] #29305
08/27/06 10:46 AM
08/27/06 10:46 AM
qc
mxbeep Offline
mxbeep  Offline
qc
You can also get the 1/2" clamp at Graingers for $2.64 part # 1L660
Where is Graingers, do they have a online store?
i tried ordering from Enco they charge $40.00 shipping on a $2.00 item.
I am in Canada not in australia
Re: The rubber hose trick on the distributor [Re: mxbeep] #29306
08/27/06 11:59 AM
08/27/06 11:59 AM
Prosport not to high jack your post but do small blocks have the same problem, my timing seems to bounce a little ? can this trick be done on the small blocks ? i have play in my shaft up and down, so wouldnt that cause the timing to jump all over being the drive gear could move up and down on the cam gear. i have a rollmaster timing chain and a tensonior on the 416 so it cant be jumping from there. thanks Bondobob
Re: The rubber hose trick on the distributor [Re: goldmember] #29307
08/27/06 12:09 PM
08/27/06 12:09 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
...Have you checked out the kit offered by Dvorak?...
Oh, you mean the one that I had Dan install on my distributor just prior to my second dyno session w/ Dwayne P, only to have it cause the entire distributor to wobble when the engine was running... and then started slipping off the shaft... after about 5 minutes of run time?
It's still sitting on my parts shelf in a zip-loc baggie... and Mr. Dvorak never bothered to reply to my e-mail asking about the issues we encountered w/ it, either.
Since I don't have a Grainger's account (they deal w/ businesses only, right?) I'll be happy to reimburse anyone who is placing an order for one of those collars shown above if they'd order a second one for me, too.
Re: The rubber hose trick on the distributor #29308
08/27/06 01:01 PM
08/27/06 01:01 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Yes it will do the same thing.
Somewhere I have one of the collars that Ed Hamburger used to sell for Mopar distubutors back in the 70's
Re: The rubber hose trick on the distributor [Re: mxbeep] #29309
08/27/06 01:07 PM
08/27/06 01:07 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Beepraz I am Canadian as well and in Canada Graingers is called Acklands Grainger. Try them---Greg
Re: The rubber hose trick on the distributor [Re: SB412DUSTER] #29310
08/27/06 02:08 PM
08/27/06 02:08 PM
thanks SB412DUSTER i will install them on my small block dist. Bondobob
Re: The rubber hose trick on the distributor [Re: bcrproducts] #29311
08/27/06 03:37 PM
08/27/06 03:37 PM
qc
mxbeep Offline
mxbeep  Offline
qc
We have one in town , i will look them up
thanks
Re: The rubber hose trick on the distributor [Re: mxbeep] #29312
08/27/06 07:31 PM
08/27/06 07:31 PM
Tennessee
DAHEMIKOTA Offline
DAHEMIKOTA  Offline
Tennessee
www.grainger.com I could give you a phone number but there are 350 locations. Akron, Ohio is :330-733-6311
The address is 420 Kennedy Rd 44305-6311. Dan
Re: The rubber hose trick on the distributor [Re: DAHEMIKOTA] #29313
08/28/06 10:34 AM
08/28/06 10:34 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks for the ingenuity!! My Barracuda is deadly consistant, but when checking timing it does move a little. That would make it easier to see. I will check local hardware first, if not thanks for the part #!! Don
Re: The rubber hose trick on the distributor [Re: cudadon] #29314
08/28/06 03:23 PM
08/28/06 03:23 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
to graingers now LOL
Re: The rubber hose trick on the distributor #29315
08/28/06 03:48 PM
08/28/06 03:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
To install it, put the clamp on the dist shaft, way down by the bottom. Tighten the clamp enuff that it won't fall off, but will still slide on the shaft. Install the dist and tighten it down. The installation will position the clamp for zero endplay on the dist shaft and intermediate shaft. Then remove the dist, tighten the clamp on the shaft so it won't slide, re-install the dist, and you are good to go.
That's exactly how I did it! Great HEMI minds think alike.
ps: I used a drop of Loctite on the screws.
Dave, your hemi eyes must of missed that "trick" componet listed in the Hamburger 340/360 Catalog circa 1979, eh?
Leigh, don't be a HATER. I never said the trick was my idea, did I? If you want to give Ed Hamburger credit for it, go right ahead. Happy now? You must be a lot older than me, because I was in my junior year of high school in '79. In the future, I suggest you NOT skank up threads with your garbage posts. Be helpful, not hateful.
am i missing something here ???
Re: The rubber hose trick on the distributor [Re: JohnRR] #29316
08/28/06 03:49 PM
08/28/06 03:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the only problem with graingers , at least a couple of local to me graingers , is they don't sell tob the general public ...
Re: The rubber hose trick on the distributor [Re: JohnRR] #29317
08/28/06 04:01 PM
08/28/06 04:01 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Fastenal is another place that's a lot like Grainger's and they do sell to the public. They may have the same collar.
Edit: yeah they do - first one I found was 88 cents
http://www.fastenal.com/web/products/detail.ex?sku=33374
Search for clamp collar - this should get you there
http://www.fastenal.com/web/products.ex?now=1&N=999603515&Nty=0
Everybody makes fun of a hillbilly until they need something fixed
Re: The rubber hose trick on the distributor [Re: JohnRR] #29318
08/28/06 04:03 PM
08/28/06 04:03 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I tried getting one from my local graingers and they wouldn't sell to me either. So I ordered one from MSC. mscdirect.com, PN-87856779 for $1.36
The only Carbs I care about are under the hood!
Re: The rubber hose trick on the distributor [Re: SB412DUSTER] #29319
08/28/06 05:01 PM
08/28/06 05:01 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Is the SB distributor shaft the same diameter as the BB distributor shaft?
There's a Grainger store nearby and, since the company I work for does a large amount of business with Grainger, I get things from there at a discount.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: The rubber hose trick on the distributor [Re: 340727dart] #29320
08/28/06 07:42 PM
08/28/06 07:42 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yes, the intermediate shaft bushing used is the same part#.
Page 2 of 4 1 2 3 4
